help with swap???
Old May 21, 2006 | 11:00 AM
b17turbo's Avatar
Default help with swap???
when swaping a b18a1 motor in a 91' crx si, do i use the stock ls shift linkage or aftermarket shift linkage????
Old May 21, 2006 | 11:02 AM
SiR Inspired ED7's Avatar
Default Re: help with swap??? (b17turbo)
u can use ur stock one and just cut it
Old May 21, 2006 | 11:07 AM
B18C1-ED8's Avatar
I'd use an aftermarket linkage. Use the same manufacturer who makes your mounts. HTH
Old May 21, 2006 | 11:09 AM
b17turbo's Avatar
Default Re: help with swap??? (88 Crx Si)
stock ls or stock crx si shift linkage???
Old May 21, 2006 | 11:13 AM
crx si linkage wont work. unless you get the SiR one from japan from the b16 crx(ef8)
efjones9
Aug 12, 2008 01:53 PM
jdmEF8racer
Mar 30, 2006 04:45 PM
CrXstEalin
Mar 3, 2004 09:06 PM
turbotime.
May 21, 2003 06:28 AM
IntegD
Jul 23, 2002 10:01 PM
