APEX'i N1!
i just ordered my apex'i n1 universal muffler. my friend's got the cat back on his teg and it looks and sounds tiiite!
i was wondering if any of you have one on your hatch or crx? if so, how did you have your custom piping done? (i.e. pipe layout, resonators, cat,etc.) also, do you have any pics of your setup, or any 4g w/ the n1? thanks.
im using the n1 universal on my car...i will tell you this...a custom bent exhaust system will not sound as good as the real cat-back from apex...it will sound raspier...i have no resonators on my custom bent piping so its pretty loud...im running 2.25" diameter piping along with a high flow cat....the n1 exits out of the stock location at a bit of an angle...it ok...it does the job....
[Modified by wuhungsixxx, 3:30 PM 4/12/2002]
I had once the HKS Hiper (similar to N1) on my crx...needed to do custom piping and some cutting to still make the exhaust come out the left side. So you don't necessarily need to have it coming out the right as TorteX says.
when my Apexi muffler goes in i will probably cut the
bumper so i get the muffler coming out the passenger side..
i dont want it sitting on an angle...
the show is too much heat for the cops around here..!
any pics of mufflers coming out the passenger side would
be appreciated.!
tia
i had the turbo n1 with 2 1/4in piping.....no cat....22in resonator......w/o the resonator that thing was HELLA loud....even with the silencer.....but with the resonator it quieted it down a lot.....really quiet with the silencer
chestnut_55
Feb 7, 2005 09:18 PM
