FS: Complete Car Audio System ( SEPA / PHILLY ) - pictures!
Complete System, Audiobahn / Sony (Drexel Hill / 19026)
400 OBO NO HEADUNIT
System consists of:
1 Audiobahn A8002T Amplifier
1 Audiobahn capacitor
1 Audiobahn AW151t 15 inch subwoofer
1 Q-Logic Box for the 15 inch subwoofer - QLH-2.2515SS (Less then 6 months old, has sub installed)
1 Lighting Audio Distribution Block LITBD3- never opened!
1 set of RCAs
About 20 feet of 4 gauge wiring About 10 feet of speaker wire (probaly 12 or 14 gauge)
2 In line fuse holder plus 2 60 amp fuses, and a new battery post terminal.
See below for pictures and more details.
Specs:
* 200 watts RMS x 2 at 4 ohms
* 400 watts RMS x 2 at 2 ohms
* 800 watts RMS x 1 at 4 ohms
* stereo or bridged mono output
* Tri-way capable (Tri-Way Crossover required)
* MOSFET power supply
* 4-gauge power and ground leads recommended
* high gloss chrome plate finish with blue illumination
* variable crossovers (50-750 Hz, 18 dB/octave high-pass, and 50-120 Hz, 18 dB/octave low-pass)
* subsonic filter (20-50 Hz)
* 18 dB bass boost (switchable on/off)
* preamp outputs
* preamp- and speaker-level inputs
* cooling fan
* fuse rating: 30A x 2
* 11-3/8"W x 2-7/16"H x 13-1/4"D
1 Audiobahn capacitor - not sure of the model but it is 1 Farad Also has a digital volt display in blue LEDs
1 Audiobahn AW151t 15 inch subwoofer - less then 6 months old
Specs:
* Optimized for Maximum Sound Quality / SPL
* PHAT 2” Foam Surround
* 120 oz. Magnet
* Non-Pressed, Non-Transfer Paper Cone
* KM3 Coated Cone for Low Cone Distortion
* Flame-Designed Cast Flame Basket
* High-Temp 2.5" ASV Voice Coil Former
* Multi-Connect Lug-Lock Terminals
* Mounting Depth: 7 1/8”
* Hole Cutout: 14”
* Outer Diameter: 15 1/2”
* Size: 15 inch
* Rec. Sealed Box Dims: 1.25 - 3.25 cu.ft.
* Rec. Ported Box Dims: 1.65 - 3.7 cu.ft
* Free Air Usage: not recommended
* Sensitivity: 94 dB
* Frequency Response: 22-700 Hz
* Recommended RMS Power: 650W
* Peak Power Handling: 1300W
* Impedance: 4 ohms subwoofer wiring options
Description:
Lighting Audio Bolt Series features solid machined brass construction with hard gold plating for reliable connectivity. The BD3 is ideal for connecting amplifiers and fused distribution blocks. It feature a clear base and snap-off cover with etched logo. The BD3 accepts two 0/1 gauge inputs and three 4 gauge outputs.
Sepcs:
Details:
» Type 2 hatchback style enclosure for one 15" subwoofer
» 5/8" medium density fiberboard construction with gray carpet covering — additional 3/4" front panel supports woofer
» nickel-plated, spring-post speaker terminals
» optional interchangeable baffles accommodate non-round subwoofers
» QXs mounting ring
» internal volume: 2.25 cubic feet
» dimensions: 26-1/2"W x 17-1/2"H x 17"D1 x 12"D2
1 set of RCAs
I have receipts for everything besides the amplifier and capacitor, must have lost them. Have original box for headunit.The sub and box were purchased and February, I am buying a new car and want to keep the sound system stock. Everythhing is in average to good condition cosmetically, everything works as described (sounds good too. To install the headunit you will need to buy a kit for your car, but I have everything it came with. Email me with any questions. If I have anything else laying around I think you could use I will add that into it as well.
Asking $400 OBO
Pictures can be found at http://s81.photobucket.com/alb...ereo/ Better pictures will be available sometime next week, these ones are with a cell phone.
Modified by Nors at 5:59 PM 6/15/2006
400 OBO NO HEADUNIT
System consists of:
1 set of RCAs
Specs:
* preamp outputs
* cooling fan
Specs:
* 120 oz. Magnet
* Hole Cutout: 14”
* Size: 15 inch
Description:
Sepcs:
Details:
» QXs mounting ring
1 set of RCAs
Asking $400 OBO
mmmVTEC
May 2, 2004 04:21 PM
