Skunk2 Pro 1 cam specs needed. (no cam card)
Bought a set of Pro 1's brand new still in the box, no cam card included
Looking for lift / duration at advertised.
iv searched myself and have gotten mixed results, skunks site lists the duration of both intake and exhaust cams for the pro 1's @ 264*
Though i have contacted someone i know with a set of pro 1's and his cam card read 264* intake duration / 245* exhaust duration.
SO... which is true ? iv got my degree wheel and indicators all set up on this motor and im getting 274* duration on the exhaust side!!!!
which, doesn't match the site or the cam card! im stumped.
if anyone has intake valve open/closing degree specs along with exhaust valve open/closing specs those would be great to have also
my head has been cut & block decked, so i know im not at true zero.
im going to need to adjust for them to be opening/closing @ proper crankshaft rotation, but i don't have these specs.
Anyone with information i would greatly appreciate a reply.
Are the cam card spec's in 1mm or .050" and which were you using. I would be willing to bet your measuring the advertised durration at 0 lift and not at 1mm or .050" lift.
measuring everything at 1mm / .039" lift.
Here are some specs i found from another user
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itgsr98 »</TD></TR><TR><TD CLASS="quote">Here are all the specs for pro1's
Intake
264deg./12.6@1mm/0.000" lash
Exhaust
264deg./11.9@1mm/0.000" lash
Valve Clearance(cold)
Intak:0.0007"
Exhaust:0.0008"
Intake:
Opening: 24deg. BTDC
Peak lift: 98deg. ATDC
Closing: 50deg. ABDC
Exhaust:
Opening: 56deg. BBDC
Peak lift: 105deg. BTDC
Closing: 17deg. ATDC </TD></TR></TABLE>
I attempted to do this 3 times last night, each time ending with the same results.
My lift is dead on at 11.9mm, but my duration is giving me a reading of 274*
its like i have the lift of a pro1 and the duration of a pro2 .. wtf.
this is all only regarding my exhaust cam. i havnt even moved to the intake cam yet.
Intake
Exhaust
Intak:0.0007"
Exhaust:0.0008"
Intake:
Exhaust:
haha its not my eyes. I took a breath of fresh air, re zero'd everything and went from there.. duration is right at 264.
for anyone degreeing a set of pro1's, the numbers i qouted above, the closing degree's are wrong. just figured id point that out so people arent chasing after answers like i was.
Set your opening angles at 56 and 24 and you should be good.
for me to get to those numbers i had to advance intake and exhaust cam 2 marks on the gears.
Modified by on_motor_only at 6:31 AM 5/22/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by on_motor_only »</TD></TR><TR><TD CLASS="quote">for me to get to those numbers I had to advance intake and exhaust cam 2 marks on the gears.
Interesting. I found the Pro1's wanted to be at +5.5, +4 when tuning on the dyno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">
Interesting. I found the Pro1's wanted to be at +5.5, +4 when tuning on the dyno.</TD></TR></TABLE>
+3 +4 for me on thre dyno
