NSX airbox w/ ABS
Old May 20, 2006 | 10:31 PM
Solscud007's Avatar
Default NSX airbox w/ ABS
Aight so I finally got a NSX airbox. Now I dont have an ITR. but I figure you guys might be interested. This was inspired by the Real Time Racing ITR.
Here is the picture that inspired me and the article in team-integra
http://www.team-integra.net/fo...earch
Here is mine.
It came with a K&N airfilter for the box. but I didnt like the flat filter design.
I modified my stock airfilter elbow and it fits thru the stock hole. For some reason the previous owner drilled a 3 inch hole in the side of the box. so I had to plug that up.
I cut the bracket supports off the airbox cause the box is so huge.
Next I planned to relocate my coolant tank. Im not too satisfied with its placement. Im thinking of moving back to where the battery is. there is a nice area to put it in. jsut need to plan out where to mount the bracket.
I also had to shorten my radiator hose cause it got in the way of the box.
Here is where I relocated the coolant tank.
oh yeah the the most important thing. Im using a customized stock filter elbow with an AEM filter.
I used this with my stock airbox and a DIY icebox snorkel.
The current setup seems to made my car a beast. I notice a huge improvement in torque and top end power.
But then It could be just my imagination. but I dont remember my GSR being this beastly. its cool haha.
Old May 20, 2006 | 10:42 PM
rough_draft's Avatar
a beast aye?
Old May 20, 2006 | 10:46 PM
JjuuN R's Avatar
Default Re: (rough_draft)
hmmm, nice stuff here, i think it's worth trying out for sure. but did you just say you were thinking of moving your coolant overflow tank all the way up by the battery??
Old May 20, 2006 | 10:54 PM
Solscud007's Avatar
Default Re: (JUN.R)
yeah I figure a longer hose. why would that not work?
Old May 20, 2006 | 10:56 PM
JjuuN R's Avatar
Default Re: (Solscud007)
not saying it wouldn't, i kind of like where it's at now
Old May 21, 2006 | 01:05 AM
vivid 02's Avatar
Default Re: (JUN.R)
Has anyone ever done dyno numbers before and after this airbox mod? Or any track numbers?
Old May 21, 2006 | 06:23 AM
RagingAngel's Avatar
Default Re: NSX airbox w/ ABS (Solscud007)
Thanks for the pictures.
Might I be able to convince you to remove the cover of the NSX airbox and see just exactly what you have done inside?
Old May 21, 2006 | 08:07 AM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
Default Re: NSX airbox w/ ABS (RagingAngel)
to you for trying something different
Old May 21, 2006 | 08:29 AM
itr1244's Avatar
Default Re: NSX airbox w/ ABS (rino924)
that's pretty interesting
Old May 21, 2006 | 08:40 AM
hybrider's Avatar
Default Re: NSX airbox w/ ABS (itr1244)
thats great and all but numbers before and after are essential.
Old May 21, 2006 | 10:02 AM
Solscud007's Avatar
Default Re: NSX airbox w/ ABS (hybrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrider &raquo;</TD></TR><TR><TD CLASS="quote">thats great and all but numbers before and after are essential.</TD></TR></TABLE>
yeah I wish, I wanna get my car dyno.
Old May 21, 2006 | 07:45 PM
frozenb's Avatar
what is the different if you using an AEM filter??is the filter for NSX? i thought it just a bigger filter from what i saw on every NSX.
Old May 21, 2006 | 09:03 PM
Solscud007's Avatar
Default Re: (frozenb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frozenb &raquo;</TD></TR><TR><TD CLASS="quote">what is the different if you using an AEM filter??is the filter for NSX? i thought it just a bigger filter from what i saw on every NSX.</TD></TR></TABLE>
Well due to the NSX box design there inst much for the intake arm to attach onto. (might be due to the original owner cutting the outlet a bit short. Our intake arms attach to the filter and the box closes around the filter.
Also the NSX filter is like the EK civics. It is a large flat element. not cylindrical like ours. So i used my AEM CAI filter from my old civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the pictures.
Sure thing. I will take pics for you.
Old May 21, 2006 | 10:17 PM
Solscud007's Avatar
there hope that helps.
also the stock elbow fits jsut right in the holes so there are no gaps.
Old May 21, 2006 | 10:22 PM
MilFhunter001's Avatar
what is that orange **** on the airbox??. Bondo?
Old May 21, 2006 | 10:27 PM
Solscud007's Avatar
Default Re: NSX airbox w/ ABS (hondabitch)
haha, nah its silicone sealant.
Old May 21, 2006 | 10:59 PM
Wannbe Racer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solscud007 &raquo;</TD></TR><TR><TD CLASS="quote">
So you're basical using a Cone Filter with a NSX Box right ?
Have you tried using a Flat Element on that Huge Box ?
Are you planning to do a dyno comparision ?
Modified by Wannbe Racer at 6:05 AM 5/22/2006
Old May 21, 2006 | 11:37 PM
__oversea's Avatar
hahaha. whats up with that filter..
i'd rather have ice box.
Old May 22, 2006 | 01:12 AM
Solscud007's Avatar
Default Re: NSX airbox w/ ABS (Last For One)
haha yeah My filter is bent a little bit cause i shoved it in the stock airbox.
But I tried this cause of the arguement about pressurization. supposedly the larger airbox creates more pressure there by more air.
Old May 23, 2006 | 10:43 AM
itr1244's Avatar
Default Re: NSX airbox w/ ABS (NZMugenITR)
umm i will just stick to my Velocity stack
Old May 23, 2006 | 11:24 AM
Mugen Mike's Avatar
Interesting
Old May 23, 2006 | 11:35 AM
Haleiwa-Brando's Avatar
Default Re: (Kool Keith)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kool Keith &raquo;</TD></TR><TR><TD CLASS="quote">whats this doing in the ITR forum? GSR w/ NSX airbox
Looks like *** IMHO</TD></TR></TABLE>
.... Way to be proactive.
The OP stated that he read up on this conversion from information on the Real Time Racing Type-R's. I think it's relative, but this is just my stupid opinion.
OP: Your thread is completely pointless without dyno plots and comparisons. There seems to be a few places where air is possibly escaping. It just doesn't look air tight enough. Have you thought about using a generic short ram intake arm for this? Since you read up in the RTR conversion, did you see pictures of the actual RTR cars?
There is a thread floating around the Type-R section on intake systems and which perform better. As it stands the Mugen intake is the ticket, but like always, it would be interesting to see a factual comparison.
It would also be nice to know how much you paid for everything. If this system performs well, it would be benificial to those who cannot afford the Mugen intake and want to try something different.
Old May 23, 2006 | 11:40 AM
Chris N's Avatar
who cares what it looks like.
last i checked if it fit a gsr it would fit an itr.
Old May 23, 2006 | 12:01 PM
Default Re: (Chris N)
My curiosity got the best of me. I just emailed Real Time Racing a formal letter requesting information on this simple conversion. Since the Type-R has been decomissioned, I'm hoping it's not an industry secret and they can thus, share some information on it.
Old May 23, 2006 | 12:15 PM
Solscud007's Avatar
Default Re: (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote"> .... Way to be proactive.
yes valid points. and I tried to note that the power difference may be my imagination. So all of my rantings and ravings could be biased. I did acknowledge that it does need to be dynoed.
However you mention that there are possible airleaks and I assure you there are not.
The collar of the stock filter elbow is a sure and snug fit. I am looking into getting another stock NSX box that has not been mutilated.
I also took a closer look at the RTR Integra. they used the adjsutable collar from the NSX. it is an accordian style tube and that is what they used to connect box to the intake arm. I will need to get that and try that out.
It may not look pretty but it seems to do the trick. again I know I need to dyno it for real proof. This post was merely to show you guys, who might have thought about doing this but were concerned about the myth of removing the ABS, now can go ahead and try this knowing that if it fits in my car it will definately fir in your car.
