After ls/vtec swap in crx, idle, power delivery issues. What do you think.
Old May 20, 2006 | 06:16 PM
ryanplayjoint's Avatar
Default After ls/vtec swap in crx, idle, power delivery issues. What do you think.
I just swapped a ls/vtec in my 89 si crx. I am running obd-0 and the car idles like ****, and power delivery is weak and uneven. It turns new spark plugs black in like 60 sec. and the car still idles when a shop rag is stuck in the throttle body. I know the rag thing is indicating a vacuum leak but what about the extreme rich condition. The car runs better w/ the stock crx si ecu than the jdm pw0. I did not install the hasport vtec sub harness yet but the car should run w/o. Tell me what you think I have a b16 head stcok on a usdm type r piston ls block. I have an endyn breather and I eliminated the evap system. What do you think.
Old May 20, 2006 | 06:36 PM
Default Re: After ls/vtec swap in crx, idle, power delivery issues. What do you think. (ryanplayjoint)
com' on man, whatever comes to mind.
Old May 20, 2006 | 07:21 PM
ok i'll start. I 'm gonna start w/ a new cap and rotor thenlook for a vacuum leak from the intake manifold back.
Old May 21, 2006 | 03:55 PM
dam, i'm on my own i guess
dark_reverie
Aug 15, 2014 12:39 PM
almostjdmeg
Jan 13, 2009 05:54 AM
whissepoo
Sep 6, 2008 09:18 PM
hai_tech
Sep 1, 2008 07:57 PM
VTECth1s
Nov 17, 2005 12:27 PM
