Coolant leak, need help (pics) pls
Old May 20, 2006 | 03:56 PM
vtakvtrak's Avatar
Default Coolant leak, need help (pics) pls
So I just notice today driving home from work when i got home there was a little bit of white smoke coming from my hood and realize the coolant bottle is empty, so i refilled and took some pics, does anybody know what parts these are and what I need to fix/replace. Thanks
Old May 20, 2006 | 05:33 PM
ekek888's Avatar
Default Re: Coolant leak, need help (pics) pls (vtakvtrak)
its really straightforward. run the engine till u see where the leak comes from. its usually from the rubber hoses and replace.
Old May 20, 2006 | 07:52 PM
vtakvtrak's Avatar
Default Re: Coolant leak, need help (ekek888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekek888 &raquo;</TD></TR><TR><TD CLASS="quote">its really straightforward. run the engine till u see where the leak comes from. its usually from the rubber hoses and replace.</TD></TR></TABLE>
thanks, i'll try that, i'll replace all the hoses
Old May 21, 2006 | 12:03 PM
boostnhoe's Avatar
This is where your leak is most likely from.... That coolant line that is blocked offed is most likely leaking from the base of that tube....
this second pick is an engine breather and has no coolant what so ever running through it....
[/QUOTE]
Old May 22, 2006 | 11:50 AM
vtakvtrak's Avatar
Default Re: Coolant leak, need help (boostnhoe)
all fixed! thanks guys, this even fixed my idle surge problem
Ace2.0
Mar 4, 2009 05:33 PM
Razr2
30
Jan 13, 2008 01:12 PM
perpetualburn
Nov 2, 2007 10:51 AM
bucaeah
Jul 14, 2007 08:32 PM
vtakvtrak
May 22, 2006 02:15 PM
