Question about Ecu or Apexii.
Old May 20, 2006 | 12:41 PM
frog169's Avatar
Default Question about Ecu or Apexii.
my car was stolen a while back i had a Apexi vtec controller in it with a p72. now that im hoping to get the car back up and running, What would be better to get, a P30 ecu with a Tac (if so what tac would u recommend), or stay with the p72 and get another Apexi vtec controller? its a 92 civic hatch, with a b16 swap
Old May 20, 2006 | 12:52 PM
SovXietday's Avatar
Default Re: Question about Ecu or Apexii. (frog169)
Chip the ECU and get it tuned, hands down. VAFC "hacks" screw with timing, and most systems now (crome/hondata/uberdata) can do extremely versatile things, and all for less than a VAFC.
Old May 20, 2006 | 02:58 PM
frog169's Avatar
Default Re: Question about Ecu or Apexii. (SovXietday)
if i do that then, what tach would u recommend? i want something accurate i dont wanna redline the engine cuz the tach is off. the old tach i had said i was pushing 10k rpms when i was only doing like 6k i think i was.
Old May 20, 2006 | 03:51 PM
exotik4doorcivic's Avatar
just get a stock ex/si gauge cluster or try fitting a gsr gauge cluster in there
Old May 20, 2006 | 06:11 PM
frog169's Avatar
Default Re: Question about Ecu or Apexii. (exotik4doorcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exotik4doorcivic &raquo;</TD></TR><TR><TD CLASS="quote">just get a stock ex/si gauge cluster or try fitting a gsr gauge cluster in there</TD></TR></TABLE>
im not very car litterate. :-P how much would that run to get installed or how hard is it to install?
Old May 20, 2006 | 06:14 PM
FalkenSiR's Avatar
Straight bolt on. Look on ebay.
And for the ecu, get a p28 and chip it.
Old May 26, 2006 | 01:54 AM
frog169's Avatar
Default Re: Question about Ecu or Apexii. (fast95eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 &raquo;</TD></TR><TR><TD CLASS="quote">Straight bolt on. Look on ebay.
And for the ecu, get a p28 and chip it.</TD></TR></TABLE>
p28 wont pass bar :-P, i have a p72 atm, thats in the car. cuz then ill end up buying a p28, then a p30 down the road, i should listen to my dads words "do it right the first time so u dont have to do it again later"
AlabasterSI
Apr 9, 2012 05:35 PM
ecasciaro
Nov 30, 2007 09:02 AM
SHG_EasyE
May 5, 2007 05:35 PM
eg6civic1538
May 2, 2007 09:57 PM
hatchb20
Dec 25, 2003 10:01 PM
