Ever fit type s rotors on type r brembo setup
Old May 20, 2006 | 11:56 AM
fourdoorturbo's Avatar
Default Ever fit type s rotors on type r brembo setup
I'm still trying to see if the type s rotors will fit on the type r brembo brakes? I know that brembo says that the rotors are 300mm which is 11.8 inches and on acura's site they say there 11.8 inches also is the hub off set the same on the rotor? if both type r and type s rotor were on the ground flate does one hub stick up higher then the other?
Old May 20, 2006 | 03:45 PM
97 TYPE-R 312's Avatar
Default Re: Ever fit type s rotors on type r brembo setup (fourdoorturbo)
This has been covered before. No, the DC5S rotors will not work on the DC5R hubs. Yes, they are the same overall diameter but the offset of the hub are the main issue here. One choice you could use is Mugen.
-Victor
Old May 20, 2006 | 04:46 PM
Default Re: Ever fit type s rotors on type r brembo setup (97 TYPE-R 312)
sorry i'm asking again but I didn't get the answer I was looking for last time I posted this topic. Also if it was a different topic not posted by me I must have missed it. I just wanted to know cause I purchased brakes all around before I thought about doing this swap. I don't want to waste the money if I already have everything that I can't use on the brembo setup.
Thanks
97emsedan
Honda Civic (2006 - 2015)
30
May 16, 2016 04:52 PM
DragDc2RoadEg6
Jan 23, 2006 09:20 PM
Big Phat R
Jan 15, 2002 02:25 PM
