help with timing.
Old May 20, 2006 | 08:33 AM
kcalb_3pe's Avatar
Default help with timing.
I took head off to do a gasket RR, and when i put it back on the block, set the top and bottom to TDC. Then I cranked the engine over and it just kept on bogging down and hesitating. so now i took the belt off again and tried to reset it. This is where the problem occurs, the bottom block turns to a certain point and then stops abruptly. Is it seized? Or am I just missing something? any help would be great.
Old May 21, 2006 | 09:55 AM
kcalb_3pe's Avatar
Default Re: help with timing. (92whitecx)
i figured it out already
bonev911
Sep 4, 2014 02:11 PM
crx18c1
Jan 13, 2007 08:09 PM
Lilk_hdriver
May 10, 2006 09:34 PM
W O T
Aug 22, 2005 05:50 AM
