what is a 15/16 master cylinder?
Old May 19, 2006 | 09:57 PM
mr 636's Avatar
Default what is a 15/16 master cylinder?
is that a si/gsr master cylinder?
Old May 20, 2006 | 01:57 AM
siregcivic's Avatar
Default Re: what is a 15/16 master cylinder? (mr 636)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr 636 &raquo;</TD></TR><TR><TD CLASS="quote">is that a si/gsr master cylinder? </TD></TR></TABLE>
i believe so
Old May 20, 2006 | 02:20 AM
BlueIntegraBoy's Avatar
1991 Civic EX
Old May 20, 2006 | 05:03 AM
NJcoupe's Avatar
Default Re: what is a 15/16 master cylinder? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">1991 Civic EX</TD></TR></TABLE>
+ 90-01 integra rs.
Old May 20, 2006 | 05:36 AM
IMASA's Avatar
Default Re: what is a 15/16 master cylinder? (dxcoupe.)
Most non-abs integras
Old May 20, 2006 | 09:27 AM
Targa250R's Avatar
be professional
15/16" master cylinders came in a variety of Civics and Integras with the 10.3" front brakes. Some cars with the 10.3" fronts had a 7/8" or a 1" MC though - depends on the model, year, and presence of ABS.
The '99-00 USDM EM1 Si had a 7/8" MC. The "GSR" does not have a unique brake system; it used the same brakes as all other '94-01 ABS Integras (except Type-R).
mr 636's Avatar
would these bolt up to my ek?
Old May 20, 2006 | 09:46 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr 636 &raquo;</TD></TR><TR><TD CLASS="quote">would these bolt up to my ek?</TD></TR></TABLE>
First of all, why? What brakes do you have?
Second of all, it depends on which model you take it from. It may also require reflaring a line.
Old May 20, 2006 | 09:51 AM
mr 636's Avatar
the brakes are from an integra....not sure of what year. had abs? i was told that the stock civic master cylinder isnt strong enough for the calipers of the front brakes. it should be from a gsr.
forgot to mention that im changing both front and rear
Old May 20, 2006 | 09:53 AM
siregcivic's Avatar
you gotta use the brake booster for that master cylinder.. bolt holes are different...
Old May 20, 2006 | 12:17 PM
Targa250R's Avatar
be professional
Default Re: what is a 15/16 master cylinder? (siregcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic &raquo;</TD></TR><TR><TD CLASS="quote">you gotta use the brake booster for that master cylinder.. bolt holes are different...</TD></TR></TABLE>
Not necessarily. All '96-00 Civics and '98-01 Integras (plus '97 ITR) have the 9:00/3:00 bolt pattern. This is in contrast to earlier models which had either 10:30/4:30 (non-ABS Civic) or 7:30/1:30 (Integra, ABS Civic) and thus required a booster swap to use certain MCs on certain cars.
HuskerHybrid
Mar 10, 2007 11:15 AM
Rob.
Nov 21, 2006 05:38 PM
motore
Suspension & Brakes
26
Jan 9, 2006 06:23 AM
10secwantabe
Aug 29, 2005 08:03 PM
scrap1ngsr
Apr 9, 2003 05:20 PM
