[FS]Custom CRX Car Audio
Old May 19, 2006 | 09:37 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Default [FS]Custom CRX Car Audio
Selling a complete custom CRX audio setup.
Included is:
Phoenix Gold 500.4 Titanium Amplifier
* Thermal Convection Cooled Heatsink (TCCH)
* High-Current Triple Darlington Output Stage
* Timed Acoustically Integrated Muting (TAIM)
* Tri-Linear Capability Allows Simultaneous Stereo and Bridged Operation
* Output Current Sensing Optimizes Power Supply and Output Stage
* Intuitive Crossover Selection Switch Assures Easy Setup
* 24 dB / Octave High-Pass and Low-Pass Crossovers Continuously Variable from 40 Hz to 800 Hz
* Auxiliary Outputs Route High-Pass, Low-Pass, or Full Range Signals
* Twin-T Bass Boost Circuit Provides Up to 18 dB of Boost at 45 Hz
* Superbrite Tri-LED Power-On Indicator
* Independent Thermal and Overload Protection LED Indicators
* Rugged Titanium Finish
* 24kt Gold-Plated Power and Speaker Terminals
* 24kt Gold-Plated, 2-Ounce Copper, Double-Sided G10 Glass-Epoxy Circuit Boards
* Replaceable Insulated Mounting Feet
* Audiophile Grade Capacitors and 1% Tolerance Metal Film Resistors Throughout the Audio Path
* Optional LPL44 Low-Pass Level Controller Allows for Driver's Seat Adjustment of Bass Volume
* Optional RMD Remote Monitor Display Allows Monitoring of the Amplifier's Battery Voltage, Power-On, and Thermal / Overload Status
Multi-Channel Amp Specifications
* Amplifier Type: Multi-Channel
* RMS Power @ 4 Ohms: 75W x 4 @ 14.4V
* THD at 4-Ohm RMS Power: n/a
* Bridged RMS Power @ 4 Ohms: 250W x 2 @ 14.4V
* Speaker Level Inputs: no
* Preamp Outputs: yes
* Built-In Crossovers: HP/LP
* Bass Boost: 0 - 18 dB
* Frequency Response: 20-20,000 Hz
* Signal to Noise Ratio: >110 dB
* Dimensions: 16.0 L x 10.0 W x 2.25 H
Phoenix Gold 600.2 Titanium Amplifier
* 24 dB / Octave High-Pass and Low-Pass Crossover Continuously Variable from 40 Hz to 800 Hz
* Optional LPL44 Low Pass Level Controller Allows for Driver's Seat Adjustment of Bass Volume
2-Channel Amp Specifications
* Amplifier Type: 2-channel
* RMS Power @ 4 Ohms: 150W x 2 @ 14.4V
* Bridged RMS Power @ 4 Ohms: 600W x 1 @ 14.4V
Phoenix Gold 215i Titanium 30 band graphic EQ
Still looking for specs on this one
3 Phoenix Gold 12" subs, not sure on specs on these either until I pull them out of the enclosure and verify models
2 sets of Focal 5.25" plus tweeters (model unknown right now)
Custom Fiberglass amp rack/sub enclosure and door panels(no pics of doors yet) painted silver right now. The fiberglass would need to be re sprayed to match the car they are going into.
All wiring and fuse distribution blocks are from a UK based company called IXOS. The main wiring for the system is 0/1 AWG in a flat wire configuration. The wiring after the distribution blocks is all 4AWG including ground. The RCA cables are supplied by IXOS as well. There is approx 15ft of 0/1 plus various other lengths to wire up after the distribution blocks. Coming from me (a former car audio installer) this is by far some of the nicest stuff I've worked with.
There is also a Phoenix Gold LPL for the 600.2 amp, as well as a lightning audio 1farad capacitor.
I'm sure I've missed some of the details. There is NO DECK/HEAD UNIT at all with this system.
Please do not low ball me, if you think my price is completely out of line then feel free to PM me and let me know. I'd like to sell this as a complete setup to someone else with a CRX but if I have I will start to part this all out.
Asking price is $1800 or best reasonable offer. Please do not ask me to part this out yet, as it just isn't an option. I don't have to sell any of this stuff so again, please keep your low balling to yourself. This is a show worthy comp worth setup in a CRX, all you have to do is add a head unit, and install. Hell I'll even help with the install.
Thanks for looking folks
Clayton
Old May 25, 2006 | 12:15 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: [FS]Custom CRX Car Audio (Clayton)
Sale Pending
B18Redline
May 24, 2005 05:52 PM
Rickdogg
12
Jan 6, 2005 09:33 PM
NuG
Jun 3, 2004 03:56 PM
dep1
Audio / Security / Video
Dec 15, 2003 06:23 PM
djay86
Jun 13, 2002 02:16 PM
