89 headlights fit 90 crx???
Old May 19, 2006 | 08:17 PM
90 JDM EF8's Avatar
Default 89 headlights fit 90 crx???
hey sorry if this is a common topic but i did try to search and nothing came up but i need to know if 89 headlights will fit a 90 crx with no mods at all...info is greatly appretiated...
Old May 19, 2006 | 09:08 PM
Vtakkk's Avatar
Default Re: 89 headlights fit 90 crx??? (90 JDM EF8)
pretty sure 88-91 civic/crx headlights are interchangable.
Old May 19, 2006 | 10:34 PM
civicrexsi's Avatar
NOPE... not without cutting and crap. The 88-89 civic/crx used a different mount for the side marker lights than the 90-91 (if you ever look at one you could tell because the 88-89 has two screws that are visible from the outside and the 90-91 has no screws visible). They might however work if you take the glass housings out and put them into the metal housings that were original with the car.
Old May 20, 2006 | 04:56 AM
pinecone's Avatar
Default Re: 89 headlights fit 90 crx??? (civicrexsi)
The headlights and corners are 88-89 and 90-91 unless you change both out at the same time.
Old May 20, 2006 | 05:56 AM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicrexsi &raquo;</TD></TR><TR><TD CLASS="quote">They might however work if you take the glass housings out and put them into the metal housings that were original with the car.</TD></TR></TABLE>
i have 91 sedan headlights on my 88 hatch. i simply bolted the 91 headlights to the 88 headlight housings. swap the housings
Old May 20, 2006 | 10:30 AM
90 JDM EF8's Avatar
Default Re: 89 headlights fit 90 crx??? (eda6)
alright...thanks guys...good info
Moo-Moo
13
Jul 5, 2010 12:50 AM
lived dreams
Jun 16, 2009 07:10 PM
B.S._TURBO
Nov 15, 2004 02:50 PM
Vinceg99
Nov 14, 2003 04:20 PM
ruiner17
Feb 16, 2003 03:29 PM
