FS: 97' Civic w/ 05' Enclosed Trailer & free track day
97’ Civic HB For Sale w/ 05' Haulmark Thrifty Hauler
Located in Apopka, FL (NW of Orlando)
I bought this car brand new in December 97’. My original plan was to prepare the car for H1/SPU and all it needs to complete it is a cage and safety equipment, i’m selling it now because my future co-driver purchased an LS Integra for us to run in H4/ITA and in order to help with the completion of that project my car must go. I have taken very good care of this car, and it has been meticulously maintained. Motor has always seen Mobil 1 every 3k miles or sooner, burns no oil and runs strong.
97’ Civic DX HB-130k Miles on chassis
Engine:
97’ B18C-JDM GSR Motor/Tranny-90k Miles (Approx.)
DC JDM 4-1 w/ 2.5” collector, custom exhaust with turndown terminating before rear axle, heat shielded gas tank
ACT HD/SS clutch
Fidanza lightweight flywheel
Fastline Performance stainless braided clutch line
Injen hot-air intake
Mugen baffled oil pan
Engine mount inserts
Spoon magnetic drain plugs
New water pump, timing belt, tensioner, valve cover gasket, spark plug gaskets, cam seals, alternator belt
New distributor
Apexi-VAFC
AEM cam gears
Suspension:
GSR brakes F&R
ITR Master Cylinder & Booster
Earl’s Stainless Braided brake lines
(4) 15x6.5 Buddy Club P1 w/ Kumho Ecsta V700 80% worn
OTS Koni Yellow
Ground Control coilover sleeves 450F/600R
Neuspeed 19mm sway bar w/ tie bar
Interior:
Corbeau Forza driver seat
Stock passenger seat
Stripped of all sound deadening material and interior panels except for dashboard and front door panels in preparation to receive roll cage.
Spare Parts Included:
UR Racing Crank Pulley
P72-JDM ECU
Passenger side fender
Hood, front & rear bumper covers
(2) caps & rotors for new distributor
Stock driver seat
Other miscellaneous items collected over the years
Trailer:
20' 2005 Haulmark Thrifty Hauler
Click Here for Specs
1400 miles
Added Options:
Equalizer hitch setup included as well as E-track on walls, spare tire, pit cabinet, helmet storage w/ hanger, air hose holder, hand cleaner holder, tie-down hanger & Kool-Seal treated roof.
Asking price for package deal is $12,000 and will include a free track day through
Engine:
ACT HD/SS clutch
New distributor
Apexi-VAFC
AEM cam gears
Suspension:
GSR brakes F&R
OTS Koni Yellow
Interior:
P72-JDM ECU
Stock driver seat
Trailer:
1400 miles
Added Options:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcaro »</TD></TR><TR><TD CLASS="quote">wow....thats a great ****** deal
gb...you should jump on that!!! bump for a sweet trailer/car combo!</TD></TR></TABLE>
Yeah right. I already have 2 EGs (racecar and daily driver). If I where to add a EK into the mix, my wife would kick me out
Also, I don't think my F150 SuperCrew would tow that trailer.
....Actually, you should buy it. You know how much you miss your old EK
gb...you should jump on that!!! bump for a sweet trailer/car combo!</TD></TR></TABLE>Yeah right. I already have 2 EGs (racecar and daily driver). If I where to add a EK into the mix, my wife would kick me out
Also, I don't think my F150 SuperCrew would tow that trailer.....Actually, you should buy it. You know how much you miss your old EK
Yeah, Irish Dan is the one building it and so far it's off to a very slow start. I specifically picked this trailer because I wanted to be able to pull it fully loaded with the Tundra I used to have which only had a 7200# towing capacity and now that I have my Titan 9500# it tows without no problem, so depending on your towing capacity it might tow just fine. The Equalizer hitch makes a huge difference in how the truck can handle the weight.
So Dan is coming back to the racing scene, cool! I hear you about the house bit. I'm remodeling right now and ran out of money. So, I sold my wife's BMW 540 for a 92 Civic SI :thumbsup: ...well, she took back the truck and I drive the EG
B18CJDM
Nov 17, 2006 06:34 AM
B18CJDM
Oct 20, 2006 03:43 PM
