Need help with my 97 accord
Old May 19, 2006 | 05:50 PM
agarcia89's Avatar
Default Need help with my 97 accord
k guys i have a 97 accord Lx 4cl.. i've been having some problems with it lately..sometimes when it's running it will shut off, if i try to turn it back on it will kinda start but it will die again..i have to turn the switch about 10 to 15 times before i can get it to start again..i thought it was a bad distributor but i changed that and it still does the same thing..i also changed the spark plugs and the spark plug wires..if anyone can help me out that would be awesome..thanks in advanced..
Old May 19, 2006 | 06:22 PM
BLKFLSH's Avatar
Default Re: Need help with my 97 accord (agarcia89)
You can check this link out for troubleshooting. I suspect the ignition switch though. Good luck
http://techauto.te.funpic.org/ignition.php
Old May 19, 2006 | 10:07 PM
H2290's Avatar
Default Re: Need help with my 97 accord (BLKFLSH)
If you turn the key and absolutely nothing is happening it is definitely your ignition switch.
Old May 20, 2006 | 02:27 AM
jli18's Avatar
Default Re: Need help with my 97 accord (H2290)
it happens to me whenever the weather is cold. i have to have the position on start for like 20 seconds to get it started
Old May 20, 2006 | 05:02 AM
Ross 2.0's Avatar
In a Junkyard near you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agarcia89 &raquo;</TD></TR><TR><TD CLASS="quote">k guys i have a 97 accord Lx 4cl.. i've been having some problems with it lately..sometimes when it's running it will shut off, if i try to turn it back on it will kinda start but it will die again..i have to turn the switch about 10 to 15 times before i can get it to start again..i thought it was a bad distributor but i changed that and it still does the same thing..i also changed the spark plugs and the spark plug wires..if anyone can help me out that would be awesome..thanks in advanced.. </TD></TR></TABLE>
If you play with the ignition switch then it will keep running? Do what BlackFish said
Old May 21, 2006 | 06:57 PM
agarcia89's Avatar
today i looked at my ignition and when i move the harness around my check engine light ect goes on and off and there is also a clicking sound..i did what black fish suggested..thanks man now i know for sure that it is my ignition..now my question is...if i take the ignition out is it fixable or should i not even bother and go buy one at a junk yard?
Old May 21, 2006 | 11:01 PM
HondaWrench's Avatar
Default Re: (agarcia89)
There's two possible reasons for the check engine light going on and off and the clicking sound when you move the ignition switch harness around. Either...
1. The Ignition electrical switch is faulty (the bluish green portion on this picture.)
2. There is a loose connection at the fuse box.
(This 97 Accord ebay ignition switch appears to be from a wrecker yard. )
The solution is to go to your dealer and get a free switch because the 97 appears to be under the recall. Then go to http://techauto.te.funpic.org/...2.htm to learn how to replace it. Or if you're lucky the dealer handles it all.
97irishaccord
May 2, 2017 04:01 PM
jessicamoore
Jun 19, 2014 08:07 AM
staudi24
Apr 12, 2010 06:22 AM
missniki
Aug 10, 2007 06:58 PM
notoriousB
Jan 11, 2005 03:28 PM
