Will 95 gsr header fit on OBD2 Gsr?
Sorry, I tried searching through "search", but wasn't too sure on the answer. If they don't fit, could you guys tell me why? Due to length of cat or header?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5THGENSI »</TD></TR><TR><TD CLASS="quote">yes it will fit</TD></TR></TABLE>
I don't think so. The A-pipe (underneath oilpan) is shorter on a '95, because the cat starts farther forward. Beginning around '98 or so (not the same year as OBD2) the A-pipe got longer, and the cat got shorter. The O2 sensor in '95 was mounted in the inlet of the cat, so the header (A-pipe) has no bung for the sensor.
If your factory A-pipe is OK, it may fit up to the '95 header, IF it's a 2-piece header with the same flange bolting pattern. I had a DC header & this would have worked.
Or you could use a '95 cat, but then you won't have the 2nd O2 sensor for OBD-2...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5THGENSI »</TD></TR><TR><TD CLASS="quote">the o2 is in the pipe before the cat on the ones ive put headers on. 94-95 . 96 up has their second o2 in the cat.</TD></TR></TABLE>Other way around. I owned a '95 GSR for 10 years...
aimbot
Nov 27, 2007 03:35 PM
94Oemconversion
Mar 11, 2003 12:21 PM
gsrboy01
May 1, 2002 09:43 PM
