MPFI conversion help
Old May 19, 2006 | 05:30 PM
Performance Freaks EH's Avatar
Default MPFI conversion help
im currently in the middle of the conversion. i have a DPFI harness and the whole Risistor box side of the MPFI harness. im splicing the two together. all the tape has been takin off all the fuel injector wires so right now theyre not in any certain order. i cant figure out which injector wire is which. know where i can find the order going by # and colors?
Old May 19, 2006 | 05:56 PM
EG8R's Avatar
Default Re: MPFI conversion help (Performance Freaks EG)
Injector #1 to the yellow wire that went to the secondary DPFI injector.
Connect the Red wire from injector #2 through the wirewall, and leave it by the ECU
Connect the blue wire from injector #3 to the red wire that went to the primary injector.
Connect the Yellow wire from injector #4 and through the wirewall the same as you did with #2.
dem0nk1d
Aug 16, 2007 02:58 PM
ivanson
25
Nov 15, 2005 09:04 PM
Magic Wheels
Jul 17, 2004 02:03 PM
thegreatwhitehope
Mar 30, 2004 09:53 AM
zccrx
Apr 2, 2003 07:03 AM
