What fittings to use to attach vacuum lines to intake manifold?
Old May 19, 2006 | 04:20 PM
Attoir's Avatar
Default What fittings to use to attach vacuum lines to intake manifold?
I'm dropping in a new motor in my SOHC w/ greddy kit, and I'm wanting to attach all my vacuum lines for boost gauge, bov, etc, directly to my intake manifold. Like a GE vac manifold, but built into intake mani. What is the best method to do this?
I know drilling and tapping, and using hose barbs would work, and be the simplest.. But I don't like how they look, and I don't like the idea of that many small hose clamps.
Any ideas?
Old May 19, 2006 | 05:42 PM
Schister66's Avatar
Man U FTW
just cut and splice the vaccuum line running to the brake booster on the engine side of the valve. That's what i did and it runs just fine...
Old May 19, 2006 | 05:59 PM
Attoir's Avatar
Default Re: (Schister66)
That's how it's setup now. I don't like plastic T's in the engine bay.
Old May 20, 2006 | 10:18 AM
Laserjock's Avatar
Default Re: (Attoir)
you can try 1/8" NPT to barb.
Old May 20, 2006 | 11:59 AM
Attoir's Avatar
Default Re: (Laserjock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laserjock &raquo;</TD></TR><TR><TD CLASS="quote">you can try 1/8" NPT to barb.</TD></TR></TABLE>
Christ man, read my freaking post...
Old May 20, 2006 | 01:26 PM
Schister66's Avatar
Man U FTW
well if you have time to blow, take off the intake manifold and drill and tap the holes on the bottom side, then run the vaccuum lines to that point. It would be basically the same as a GE Vaccuum manifold except built into your manifold....that would be the cleanest way to do it, but definately the most time consuming!
Old May 20, 2006 | 09:13 PM
Attoir's Avatar
Okay, nobody seems to understand what I'm saying.
I will have the motor out, and intake manifold off. I am planning on drilling and tapping the intake manifold for vac lines.
But I don't want hose barb fittings coming off the back of my intake manifold, because I don't like how they look with hose clamps, and I want something secure.
Old May 20, 2006 | 09:17 PM
.God.'s Avatar
custom formed gold pipe with titanium V band ends.
Old May 21, 2006 | 06:36 PM
Laserjock's Avatar
Default Re: (.God.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .God. &raquo;</TD></TR><TR><TD CLASS="quote">custom formed gold pipe with titanium V band ends.</TD></TR></TABLE>
oMFgrscrappoola! not good enough! must meet NASA requirements and withstand a 10 megaton nuclear yield and a bunch classroom full of 8 year olds. but must match my beige trim on my velvet liner.
seriously dude, barb hose fittings work fine for this purpose. anything else is overkill or ****. but if you must, you can use hydraulic hose fittings,
or search for "Glass-Filled Nylon Department of Transportation (D.O.T.) Fittings" on page 155 of the http://www.mcmaster.com
i hope that meets your approval
losopontes
Oct 14, 2008 01:03 PM
1.8
Dec 26, 2004 09:38 PM
GruvyTune
Aug 24, 2003 07:36 PM
