96-98 civic headlights adjustment
Old May 19, 2006 | 02:00 PM
aznrexboi00's Avatar
Default 96-98 civic headlights adjustment
Hello, I have a 98 civic and i need to adjust the headlights, i've already search and the posts that i saw was unclear about this. Behind the headlights there are 2 screws and a 10mm bolt...i've been twisting and turning the screws...i see it moving...but how do i actually know when its aligned? im aware that the screw closes to the grille is the horizontal and the one closes to the fender is the verticle. So what is the 10 mm bolt that is close to the headlight? thanks in advance
Old May 19, 2006 | 02:52 PM
old man neri's Avatar
Default Re: 96-98 civic headlights adjustment (aznrexboi00)
There should actually be a mini leveling bubble in the headlight assembly. It is probably covered in grime. If you look in your manual I think it explains how to do it with pictures.
honda_boy23
Mar 14, 2010 09:13 PM
donz
Jun 13, 2006 10:15 AM
DYRcivic
Aug 1, 2005 10:56 AM
jmad08
Mar 4, 2002 05:09 PM
