need ebrake help asap please
guys i need some help my e brake wont hold at all if im on any kind of incline even a slight incline thought it was my rear brake pads so i changed them and ran into a problem there to my driver side rear piston wont compress enough for me to use both new pads no mater how many time i turn nothing same postion so i had to use one of the new pad the inner one but had to use old outer pads so what could be the problem because the e brake still wont hold at all i have to use my gear to hold in place and sometime that wont work and have to use a brick so i need some help asap
https://honda-tech.com/zerothread/1632750
sounds like you guys have same problem, could be same solution... not sure why you cant replace the rear pads, you shouldnt have to use the old ones simply because they are skinnier... i would consult one of your boys familiar with the brakes on your car are set-up, you might have to just tighten your cable...doesn't sound like your going to be able to fix this on your own from your description
R_ACE1
12
Aug 16, 2009 12:53 PM
