Help with Installing Aeromotive FPR (P/N 13105 )
I just purchaced an Aeromotive FPR that has one inlet and one outlet, and I am not quiet sure how to hook this up to my BDL fuel rail. The fuel rail has inlets on either side and currentlu has the stock FPR on the rail, so do I just need to plug that hole then? Anyways any help would be great, here is a link to the FPR http://www.aeromotiveinc.com/l...&th=1 Thanks
after the outlet of the fuel rail install a 6an fitting then either use a female 6an adapter and fuel hoes (stainless socketless whatever) then run another 6an female connector on the side of the fpr (inlet) then run the bottom line to the return. either by using a 6an to barb fitting adapter or 6an to female connector the return line.
btw my set-up is after fuel rail 6an to 6an then a female 6an to 6an to the 6an on my fpr then on the return a 6an to4an adapter then 4an line to the return hose then a spectra magna hose clamp.
http://www.summitracing.com
13105, acura, aermotive, aeromotive, areomotive, civic, diagram, fpr, frp, honda, inlet, install, installation, installing, part
