Omni power coilovers (sleeve type) Weird vibration?
Old May 19, 2006 | 11:15 AM
Kris's Avatar
Default Omni power coilovers (sleeve type) Weird vibration?
So I installed these yesterday on my CRX and everything went well, had it done in no time but now I notice that under deceleration there's a vibration coming from the front, not sure if it's both sides, I put the car back on the lift, checked that everything was torqued...looked everything over 3 times...as it came off it went back on...but I don't know if this is normal or not...the only thing I could think is maybe it's the sleeve rattling around but I put those rubber rings that came with the kit in so I still don't know why it would do this especially only when it's decelerating...anyone else experience this with sleeve type coil overs? This is the first time I've had coilovers on my car and it's on stock bushings (which are going to be upgraded to energy suspension) and stock shocks (which are probably blown but are also getting upgraded).
Old May 19, 2006 | 11:50 AM
Kris's Avatar
Default Re: Omni power coilovers (sleeve type) Weird vibration? (Kris)
Actually, delete or lock this, I'll post it in suspension, should have done it there in the first place...
Old May 19, 2006 | 12:07 PM
kcjohnnyboy's Avatar
Default Re: Omni power coilovers (Kris)
i have the same problem in my 90 rex...im not sure yet of what it is but i know what you're talking about, sometime this weekend i will look at it... hopefully you know what it is before i do hahah
Old May 20, 2006 | 01:31 AM
M15's Avatar
M15
Default Re: Omni power coilovers (kcjohnnyboy)
I think it is more or less that the omni power sleev coilovers are complete pieces of ***, . .. you would have been betetr off with springs.
EGG^6
Jan 24, 2007 06:13 AM
eastbayrep
Dec 23, 2006 07:54 PM
GS-R Power
Jul 27, 2006 02:43 PM
Kris
Suspension & Brakes
May 20, 2006 09:29 AM
Blazeone
Mar 29, 2003 07:25 PM
