86 crx si help
Old May 19, 2006 | 08:11 AM
joesbadcrx's Avatar
Default 86 crx si help
i got a 86 crx si that is about to blow up.I got a 88 acura integra lined up to buy and i want to put that motor in my crx.How hard is it and what all do i have to do?ANy help would be great.
Old May 19, 2006 | 08:16 AM
jlicrx's Avatar
Default Re: 86 crx si help (joesbadcrx)
you need to use the Integra D16A1 engine, transmission, ECU, intermediate shaft, axles, shift linkage and knuckles hubs - everything bolts right in using the Si mounts
Old May 19, 2006 | 08:21 AM
joesbadcrx's Avatar
i got all of it i just dont know if everything will just hook up and run or do i have to wire anything up?
Old May 19, 2006 | 10:02 AM
vtecn8ive's Avatar
Default Re: (joesbadcrx)
You will have to do extensive wiring. You will need to convert the car over to electronically advanced timing. where the si is vacuum.
A 86-87 Integra is a straight drop in with very little mods needed. No wiring needs to be done.
Want to sell your car?? . I've been looking for a cheap 1g CRx si with a motor about to go
Old May 19, 2006 | 10:08 AM
ludesrv's Avatar
He's right. 86-87 is straight swap, anything else if ALOT of wiring. Good luck man.
Old May 19, 2006 | 11:05 AM
vtecn8ive's Avatar
Default Re: (ludesrv)
http://www.redpepperracing.com is all 1g ****
1stGenHmlae
Mar 5, 2007 06:42 PM
illcrx
18
Mar 12, 2005 12:12 AM
jagged4698
Aug 1, 2004 06:13 PM
GroundZer0 336
Aug 13, 2003 10:35 AM
