I need to know a few wire colors PLEASE HELP
Old May 19, 2006 | 06:30 AM
martingouda's Avatar
Default I need to know a few wire colors PLEASE HELP
i did do a fas search and i found pin outs but not colors...
i have a 1993 delsol si with a OBD1 P28 ECU and i need to know where i can make some conections and what color they will be
i am installing a pioneer AVG VDP1
i know most of the conections already but....
i need to know
1)where i cange find a wire that changees voltage when the car is in reverse
2)what color is the speed detection wire at the ecu
3)what color is the tach lead at the ecu for RPM
thanks in advance
Old May 19, 2006 | 06:33 AM
tatmark1's Avatar
if you found pin outs look at that location and you will see what color it is. go gget a manual it will have wiring diagrams in it!!!!
Old May 19, 2006 | 06:39 AM
thanks for the help....
now can some one that actually has something to add help me?
Old May 19, 2006 | 06:41 AM
tatmark1's Avatar
that is help. use that info and help yourself
Old May 19, 2006 | 06:44 AM
i wanted wiring colors... i ofund the pin outs but i am not looking to make mistakes so i would prefer to be 100% aware before i start the work
Old May 19, 2006 | 06:47 AM
tatmark1's Avatar
hmm thats where the wiring diagram comes in
Old May 19, 2006 | 07:20 AM
ok then what sthe speed and tach pins?
Old May 19, 2006 | 07:27 AM
tatmark1's Avatar
i dont have that **** in front of me.get off your *** and do it your self.......
you want to be 100% aware but you will blindly trust what someone may say here? if you have a manual with wiring diagrams there you go hell even go to the dealer and some will print them out for you.
you sat here for an hour waiting for an answer when you could have had it on your own
Old May 19, 2006 | 08:28 AM
honda tech rules....
thanks
EKIM NART
Apr 26, 2005 03:36 PM
00bluesi
May 3, 2004 08:45 PM
CTRwannaB
Dec 6, 2003 04:52 PM
turbospool
Aug 4, 2003 11:38 AM
typer77
Mar 27, 2002 11:03 AM
