need help with a engine swap!!!!
Old May 19, 2006 | 05:56 AM
Bseries!EF!hatch's Avatar
Default need help with a engine swap!!!!
I am putting a B18A1 LS swap in my 91 ef i was told that i need a jumper harness is this true can someone help !!!
Old May 19, 2006 | 06:01 AM
FastReligion's Avatar
you should search it up, because you're not giving us a clue what year model ef you have, you can use your stock harness, if you have an Si model than it should just plug and play, if you have a dx model you're going to need to do the dpfi into mpfi conversion.. try the search button there are answers every where.
Old May 19, 2006 | 07:03 AM
thevtecnician's Avatar
Default Re: (FastReligion)
If you are going to run the motor as obd1 then u need a ecu jumper harness. The b18a1 is an obdo motor you just slap it in and go if you have an si
Old May 19, 2006 | 08:24 AM
Default Re: (thevtecnician)
The EF is a 1991 si and the motor is a 1992 integra LS 'DA' what i understand is that the stock harness in the ef will plug up to my da computer! correct!!!!
94hondaLS
25
Apr 6, 2025 08:41 PM
juanhda9
Dec 24, 2010 02:03 PM
Lao17
22
May 31, 2010 07:51 PM
moskaEF9
Aug 11, 2009 06:34 PM
