turbo questions
hey there, whats the turbo that bolt on an HF manifold?! i'm going to order the turbo so i need to know the best one for hondas.
another question, whats the best OEM pistons for my D15b vtec that gives me low compression, i'm running it on a pm6 ecu.
Well i don't know of a turbo that bolts directlythe Hf mani but there are adapter plates made to bolt up pretty much any turbo you want, look on homemadturbo.com
For compreesion ratio check out this:
http://www.c-speedracing.com/h....php
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac »</TD></TR><TR><TD CLASS="quote">Well i don't know of a turbo that bolts directlythe Hf mani but there are adapter plates made to bolt up pretty much any turbo you want, look on homemadturbo.com
http://www.c-speedracing.com/h....php </TD></TR></TABLE>
That's partially right. No turbo bolts directly up to an hf/std manifold. You have to get an adapter plate although they don't make one for t3/t3's on an hf/std manifold. So basically your options are t25's and t28's or Mitsu DSM TDO5 turbos.
yea you have to get an adapter plate. i actually think some companys do make a t3/hf adapter. best bet would be to check out homemadeturbo.com look in the fosale thread for some sponsor threads.. hope that helps
