2002 crv ex 5 speed questions
got one cheap as a daily driver, car handles supprisingly well and is pretty quick for what it is,k24 makes good torque for a 4. but i have a few questions
i know mods ment for these are few and far between, but what can be adaped from what other honda/acura's to work on this in the way of intakes, exhausts ect.
and when the awd should kick in and you feel it the rear diff makes this crazy noise, it sounds like a daum turkey, wtf is this and how do i fix it.
The noise your hearing is the Dual Pump fluid in your rear diff that has broken down and is causing the clutch packs to make a lot of noise. Just have the fluid changed with fresh Honda Dual Pump fluid and the noise will quit.
As far as mods i'm pretty sure there is a cold air intake for it or you could get a k&N filter for it. But I think that 5spd has plenty of power anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 »</TD></TR><TR><TD CLASS="quote">The noise your hearing is the Dual Pump fluid in your rear diff that has broken down and is causing the clutch packs to make a lot of noise. Just have the fluid changed with fresh Honda Dual Pump fluid and the noise will quit.
As far as mods i'm pretty sure there is a cold air intake for it or you could get a k&N filter for it. But I think that 5spd has plenty of power anyway.</TD></TR></TABLE>
how much is fluid and can i do it laying on my back in the garage? if so ill do that this weekend when i do the brakes.
Yeah just make sure you get Honda Dual Pump Fluid like said or the exact fluid you need as there are different rear differential fluids for cr-v, pilot and others.
Always use Honda fluids on stuff like this and get the right stuff because Honda has made it very specific they are NOT INTERCHANGEABLE so <U></U>please don't try.<U></U>
Hope this helps and checkers or autozone sells a little pump that will attach to the bottle for easy pumping. Pump until it starts to overflow a little and by the time you get the plug in it will be at the right level.
Matt Powell
Honda CR-V & Element
Sep 18, 2019 06:30 PM
Padawan
Aug 25, 2007 08:29 PM
