Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor?
Old May 18, 2006 | 10:57 PM
Mr. Tech's Avatar
Default Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor?
If so what combination of axles could i put together? Im trying to swap a single cam back into my car but my 5 lug suspension is the 36mm kind.. Lmk what i could do.. TIA!!
Revised my origional post so its more clear
Ah here is the problem, i currently have a 5 lug conversion on my car, but it is the JDM Type R one which uses a 36mm Axle nut instead of a regular 32mm Axle nut. The only axle you are able to use is the JDM TYPE R axles which are the same thing as regular axles but they have a 36mm outer to fit the spindle correctly.
Now what im trying to do is figure out a way to keep my 5 lug suspension if i was going to throw a single cam inside my car.. the reason is because you cant use a b series axle for a single cam motor. Get it?
Modified by Mr. Tech at 11:58 AM 5/19/2006
Old May 18, 2006 | 11:55 PM
fmrprojects's Avatar
Default Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (Mr. Tech)
u can swap out the outer parts of the axle to the 36mm or u can get some custom upgraded axles for your single that are 36mm. or just get a b series swap and use the itr 36mm axles
Old May 19, 2006 | 12:59 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">u can swap out the outer parts of the axle to the 36mm or u can get some custom upgraded axles for your single that are 36mm. or just get a b series swap and use the itr 36mm axles</TD></TR></TABLE>
Only the JDM ITR uses 36mm axles... all USDM models are 32mm, which is where the problem lies...
Old May 19, 2006 | 04:45 AM
Mr. Tech's Avatar
Default Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (JDM_Ej)
The problem also lies.. I dont think the 36mm outers will fit onto a single cam axle will they?
Old May 19, 2006 | 07:03 AM
c_buz's Avatar
I am not really sure what your problem is but there is a company that sells 4 lug hup with 36 mm spline for the eg.
Old May 19, 2006 | 10:58 AM
Mr. Tech's Avatar
Default Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (c_buz)
Old May 19, 2006 | 11:22 AM
Targa250R's Avatar
be professional
The only real option you have is to try the 36mm outer CV onto a D-series axle (I don't know if it cant be done or not). If it doesn't work, you're SOL.
Old Aug 10, 2006 | 09:04 AM
tofu__'s Avatar
bump
i need info on this also
Old Aug 10, 2006 | 09:26 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (tofumonzter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">The only real option you have is to try the 36mm outer CV onto a D-series axle (I don't know if it cant be done or not). If it doesn't work, you're SOL.</TD></TR></TABLE>
I would agree with this. Get a junk SOHC axle and a 36mm outer and see if you can put them together.
Old Aug 10, 2006 | 09:28 AM
BlueIntegraBoy's Avatar
Change the hub to a USDM ITR.
Old Aug 10, 2006 | 09:43 AM
tofu__'s Avatar
Default Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Change the hub to a USDM ITR.</TD></TR></TABLE>
What's all needed to complete the conversion?
https://honda-tech.com/zerothread?id=818454
was not much help
Modified by tofumonzter at 10:54 AM 8/10/2006
Old Aug 10, 2006 | 02:25 PM
92_VX_EG's Avatar
You can buy a ZC tranny. It uses b-series axles and works on single cams. I've never seen the hydro ZC tranny(I recently just heard of one) so I don't know if it uses the b-series axles, but I know the cable one does.
Old Aug 10, 2006 | 02:44 PM
eg6ajk's Avatar
Default Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (92_VX_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_VX_EG &raquo;</TD></TR><TR><TD CLASS="quote">You can buy a ZC tranny. It uses b-series axles and works on single cams. I've never seen the hydro ZC tranny(I recently just heard of one) so I don't know if it uses the b-series axles, but I know the cable one does.</TD></TR></TABLE>
36mm outer joints do not work with d-series axles. ZC DOHC is rather rare but 94 JDM Integra SOHC used half shaft and b-series driveshafts as well, its fairly common.
easiest way is to get usdm or CTR 5bolt front or trade with someone who is going to do a k-series swap
Old Aug 10, 2006 | 03:44 PM
tofu__'s Avatar
Default Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (eg6ajk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk &raquo;</TD></TR><TR><TD CLASS="quote">36mm outer joints do not work with d-series axles. </TD></TR></TABLE>
even if i have an axle shop custom make me the whole thing if possible?
Old Aug 10, 2006 | 06:23 PM
Bense's Avatar
do this. get a zc differential (i have one) take your tranny apart, and do a differential swap. shim the differential so that it doesn't expletive up your bearings. and then get a d16a6 block and tap the threads and use the zc midshaft. AND THEN build the hybrid axles with the 36mm teg outer joints. DONE!
lol
Old Aug 15, 2006 | 10:30 AM
Katman's Avatar
If you pay me the $50 you still owe me for the ARP rod bolts, I'll give you some solutions
Old Aug 16, 2006 | 06:34 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (Katman)
ya if you stopped scamming people they might help you
Old Aug 16, 2006 | 06:57 PM
E46Kid's Avatar
This guy is a lame Scammer
Old Aug 16, 2006 | 07:23 PM
.Beaver's Avatar
Bloody Beaver
Default Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (Em1Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Em1Kid &raquo;</TD></TR><TR><TD CLASS="quote">This guy is a lame Scammer </TD></TR></TABLE>
not to mention a douche with a 5 lug and a wicked sweet SOHC.
Old Aug 16, 2006 | 07:28 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (.Beaver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Beaver &raquo;</TD></TR><TR><TD CLASS="quote">not to mention a douche with a 5 lug and a wicked sweet SOHC.</TD></TR></TABLE>
nothing wrong with 5 lug and sohc!
Old Aug 17, 2006 | 10:21 AM
Katman's Avatar
Just an update...
Mr.Tech has sent me a pending Paypal eCheck refund today. Once this clears within about 3 days, he'll be taken off my black list and I'll rescind my gripes about our transaction.
Thanks for being responsible about this Mr. Tech
Old Aug 17, 2006 | 10:49 AM
Bense's Avatar
Default Re: (Katman)
why don't you take the drama out of the tech threads?
Old Aug 17, 2006 | 10:51 AM
Katman's Avatar
Default Re: (Bense)
because Mr. Tech wasn't replying back to my IM's for a few weeks now.
Had to make some kind of noise about it...
Old Aug 17, 2006 | 10:59 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">
Only the JDM ITR uses 36mm axles... all USDM models are 32mm, which is where the problem lies...</TD></TR></TABLE>
There is actually a US B-series 36mm outter joint, which can be found on the CRV.
Here's your options Mr. Tech:
1) I'm not 100% sure if this works, but you can try adapting 36mm CRV outter joints to the SOHC axles. If thats found incompatible, the next option would be...
2) Sell/trade your 98+ JDM ITR front spindles for that of US 5lug ITR spindles which accept 32mm outter axle joints. ....or...
3) purchase a set of US ITR 5lug hubs (32mm) and have your 36mm hubs pressed out of your spindles and have the 32mm hubs pressed in.
Ekstan
Suspension & Brakes
Mar 5, 2019 08:56 AM
Mikeyb918
Nov 10, 2012 08:26 PM
redb16coupe
Honda Civic (2001 - 2005)
Dec 30, 2009 02:42 PM
kazino42
Aug 31, 2009 09:14 PM
Savage211
Aug 25, 2008 06:21 PM
