Stock exhaust too short?...or is my car just 2 inches longer?
Old May 18, 2006 | 10:23 PM
Simple SOHC's Avatar
Default Stock exhaust too short?...or is my car just 2 inches longer?
Alright...I've been tryin to get the exhaust situation straightened out on my 95 EX Coupe and none of my stock exhausts fit. I've tried with stock header, dc header, and no-name aftermarket header...all of which worked on my 93 Coupe just fine. I tried my cat from my last car also...but both are the same size. The B-pipe is 2 inches too short in the long straight section where the resonator is. If I bolt it up to the header and not the axle back...the first 90 hits the car. All of my B-pipes are the same length and worked on my last coupe. I'm clueless...
Old May 19, 2006 | 12:10 AM
fmrprojects's Avatar
Default Re: Stock exhaust too short?...or is my car just 2 inches longer? (Simple SOHC)
are you sure that all the rubber is on all the way and that its in correctly
Old May 19, 2006 | 09:22 AM
Default Re: Stock exhaust too short?...or is my car just 2 inches longer? (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">are you sure that all the rubber is on all the way and that its in correctly</TD></TR></TABLE>
Yup...I'm positive. When it sits on just the hangers...it doesn't it hit the car...it sits perfect...but the flanges are like hella gapped. When I start to bolt the header and exhaust...there is hella tension and it rubs the car.
Hey Mike...did you guys work on David's car yet?
Old May 19, 2006 | 09:42 AM
ProjeKt's Avatar
In Basic Training
If you dont want to spend the money then buy an aftermark can
Old May 19, 2006 | 09:46 AM
Well if I do get an aftermarket exhaust...wouldn't that not fit also? It's goin to be the same length as my stock one...so how would that fix it?
Old May 19, 2006 | 09:31 PM
Bump for answers
Old May 19, 2006 | 09:51 PM
SiYouLater's Avatar
maybe its for a hatch?
ep3man
Sep 1, 2008 12:51 AM
95civiccpdx
Jan 20, 2008 05:10 PM
scrcrw
Oct 29, 2007 02:27 PM
Thirty-Nine
Aug 21, 2002 05:07 AM
