ITR JDM Header Specs...If You Care
After cutting one of these up today, I finally got to measure the wall thickness of the primaries.
Wall thickness is 1.5mm
Primary OD is 43mm (all the other JDM headers are 45mm.
Stock Collector
Collector Going On A Diet
This will get cut off also
[Modified by SMSP, 7:27 AM 4/12/2002]
That collector looks familiar....
I'm going to try a H22 stepped 4-1 header and will open this collector up to receive some 1-7/8" tubes. This collector will also get a tapered outlet that will open to 2-1/2" and I'll replace that flange since it is much bigger than my regular 2-1/2" collector flanges. I'll hopefully have some pictures of the header Saturday night if all goes well.
I plan to do the same thing for a B18C set up. I just need another trashed ITR JDM header for another collector or I'll just make a cone and shape it into something similar.
What's that the JDM 4-2-1?
I'm going to be building a stepped 4-1 for the H22 today and I'm building a prototype for the B18C also.
It's the stock European spec Accord Type R 4-2-1. The stock Euro ITR 4-2-1 is similar but smaller... only 40mm OD!!!
b19coupe
Sep 10, 2006 11:59 AM
How about the ID and OD of the inner tube of the collector?
