Dynoed my Pro1's today
Old May 18, 2006 | 08:00 PM
aeon's Avatar
Default Dynoed my Pro1's today *UPDATE*
setup
B16 head
Gsr block
B16 tranny
Pr3 pistons
Skunk2 Pro1 cams
omnipower valvetrain
itr intake manifold
64mm maxbored throttle body
comptech icebox intake
comptech 421 header
high flow cat
itr exhaust with a twinloop muffler
First Dyno
*UPDATE*
Well, just got my car dynoed again with a profab header and 310 injectors. A little dissapointed in the results though.
Second Dyno
Now the first tune was done in northern Ca. since then, I moved down south and it was hot and humid down here when it was tuned...
Modified by aeon at 9:03 AM 6/27/2006
Modified by aeon at 9:04 AM 6/27/2006
Old May 18, 2006 | 08:06 PM
SMSP's Avatar
Default Re: Dynoed my Pro1's today (aeon)
usdm or race header?
Old May 18, 2006 | 08:07 PM
aeon's Avatar
i think usdm..
Old May 18, 2006 | 08:11 PM
( o )( o )'s Avatar
Default Re: (aeon)
a 2.5" exhaust will make a hell of a difference
Old May 18, 2006 | 08:12 PM
EJ_ALLMOTA's Avatar
numbers look good.. tuner could iron out that dip where it runs out of low cam though..
Old May 18, 2006 | 08:16 PM
B18C1_POWER's Avatar
not bad, change your exhaust-header and you will see better #'s
Old May 18, 2006 | 08:18 PM
DATZ WEAKSAUCE's Avatar
Default Re: Dynoed my Pro1's today (B18C1_POWER)
188 at dyno spot good number fa sho
Ivan's Avatar
senior gold member
how would adding bigger injectors gain power? I've seen 240cc injectors pulling 200 whp although at max duty.
aeon's Avatar
yeah, i'm looking into a new exhaust and header right now. probably wont buy it for a while though. no money at the momment. what's a good 2.5 exhaust that isn't loud?
Old May 18, 2006 | 08:21 PM
OUT OF ORDER ROB's Avatar
nice ##'s
Old May 18, 2006 | 08:22 PM
SMSP's Avatar
Default Re: (aeon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeon &raquo;</TD></TR><TR><TD CLASS="quote">i think usdm.. </TD></TR></TABLE>
If it would bolt to the stock exhaust then it's a USDM header.
Old May 18, 2006 | 08:24 PM
aeon's Avatar
Default Re: (SMSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">If it would bolt to the stock exhaust then it's a USDM header.</TD></TR></TABLE>
then yes it is usdm.
does torque seem a little low??
Old May 18, 2006 | 08:26 PM
Default Re: (aeon)
yes, change the header-exhaust and lets see what happens
Old May 18, 2006 | 08:29 PM
Ivan's Avatar
senior gold member
I'm actually impressed that its a 2.25 outlet header. I bet its gonna be in the upper 190's with a good header and exhaust.
Old May 18, 2006 | 08:33 PM
SMSP's Avatar
Default Re: Dynoed my Pro1's today (Ivan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">I'm actually impressed that its a 2.25 outlet header. I bet its gonna be in the upper 190's with a good header and exhaust.</TD></TR></TABLE>
Try a 2" collector, there are no 2.25" usdm headers.
Yeh, torque seems low, even for the vtec crank.
Old May 18, 2006 | 08:36 PM
Ivan's Avatar
senior gold member
Default Re: Dynoed my Pro1's today (SMSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">Yeh, torque seems low, even for the vtec crank.</TD></TR></TABLE>
I made the same tq and a little lower hp(182) with almost the same mods but with crower cams.
Old May 18, 2006 | 08:43 PM
WhoisDan's Avatar
Not too bad. Definitely get a better header and 2.5" exhaust.
Old May 18, 2006 | 08:49 PM
strsi's Avatar
Default Re: Dynoed my Pro1's today (WhoisDan)
how well do u have it idleing with those cams?
Old May 18, 2006 | 09:04 PM
aeon's Avatar
well we were messing with the idle for awhile and couldn't get the car to stop dying. Lawrence kept raising the idle and we stopped at 1000. then he went under the hood and opened the idle screw up a little and the car idled just fine. I guess the idle screw was closed to much so the car kept dying. I haven't lowered the idle yet. Going to do that tomorrow morning and see how it goes. idle doesn't seem lumpy at all right now.
Old May 18, 2006 | 09:11 PM
bs-inc's Avatar
Default Re: (aeon)
Hey are those sweet numbers for your setup.
Old May 18, 2006 | 09:28 PM
mtber's Avatar
Nice numbers
You need a bit more dyno time
Old May 18, 2006 | 09:31 PM
aeon's Avatar
Default Re: Dynoed my Pro1's today (mtber)
yeah, first time ever getting on a dyno.
Old May 18, 2006 | 09:42 PM
ATS*Mark's Avatar
OG triple OG
whats the compression
Old May 18, 2006 | 09:56 PM
aeon's Avatar
Default Re: Dynoed my Pro1's today (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">whats the compression</TD></TR></TABLE>
Based on the c-speedracing calculator, i'm running 11.1:1
Old May 18, 2006 | 10:37 PM
b16nonoy's Avatar
bump....nice gains
