HOW MUCH IS INJECTORS
Old Apr 11, 2002 | 11:57 PM
Hnda_Crx_Man's Avatar
Default HOW MUCH IS INJECTORS
my injectors are going out on my 1985 crx si
how u think to replace them or should i go to pick and pull and get some?
not sure what to do
Old Apr 12, 2002 | 02:06 AM
Noahk's Avatar
Default Re: HOW MUCH IS INJECTORS (Hnda_Crx_Man)
I would go to pick and pull. you can also use 86-87 injecotrs and ECU. If you do use them together.
Old Apr 12, 2002 | 08:37 AM
-=TWITCH=-'s Avatar
not sure what to do
you shure its your injectors? just a thought
Old Apr 12, 2002 | 11:06 AM
Noahk's Avatar
Default Re: HOW MUCH IS INJECTORS (-=TWITCH=-)
Actually that's a good point, why do you think they're going out?
Old Apr 12, 2002 | 02:31 PM
Default Re: HOW MUCH IS INJECTORS (Noahk)
umm my fuel injection light comes on and it sends huge surges and my car runs like a lump on log =
Old Apr 12, 2002 | 02:35 PM
fixhondas's Avatar
could be a number of problems- usually some techron concentrate will bring the injectors up to par
Old Apr 12, 2002 | 08:43 PM
Default Re: HOW MUCH IS INJECTORS (fixhondas)
tried the chevron techron stuff didnt work
went to pick n pull found ****
not sure what to do
Old Apr 13, 2002 | 01:12 AM
chhuong's Avatar
What about your fuel pump???
Old Apr 13, 2002 | 10:56 AM
fixhondas's Avatar
Did you try running the Concentrate directly into the fuel rail? Honda injectors from the dealer are around $100 each. Are they not clicking or what?
Old Apr 13, 2002 | 06:46 PM
i did not try diretly from fuel rail
i changed my fuel filter might be pump not sure
how u put diretly in rail
Old Apr 13, 2002 | 09:46 PM
fixhondas's Avatar
you need something to pressurize it and hook into the fuel system.
Old Apr 15, 2002 | 09:40 PM
alright my freind said he can run a diagnostic check for and ill figure out whats going on thx for posting
Bintegra
14
Jul 29, 2004 08:11 PM
VaporTrail
Feb 11, 2002 09:23 PM
