people with b16a2 usdm swaps help!
ok on the b16a2 engine harness where does the air temp sensor plug into the harness? is it the plug on top of the intake manifold, the one im thinking its on the same part of the harness as the injectors? any help would be great!
by the way the air temp sensor is on the intake elbow right...
edit: the color of the plug wires are < green/black and red/yellow
Modified by nekoabandoned at 7:03 PM 5/18/2006
well its throwing a cel 10 so i think i need one... but ya theres that extra plug ontop of the intake mani. color of wires posted.
I think its a bit lower on the harness, mine is unused and it hangs down around my oil pressure switch actually lol, i need to extend the wires and drill a hole in my intake i just havent gotten around to it yet. may be different on yours though, mine was hacked up pretty good putting obd1 plugs on it.
On the SI harness it should be on the passenger side of your engine bay fairly should be a Black plug with either a blue or white inner plug color. One of the wires will be Red/ yellow, should be able to find it fairly easy
have you started the car already? if you got the two mixed up it will burn your air temp sensor. i did that no cel showed up for me but when tuning my car it wasnt reading temps right and when you pull the plug off you will see it burnt. so if you screw up you will need a new sensor and switch them the plugs.
CRX91SE
Mar 31, 2011 10:29 PM
