how to lower exhaust....
Hi,
Just got a reese hitch that requires no drilling but lowering the exhaust pipes. Anyone knows how to do it on a 2002 EX V6?
Also, I will highly appreciate instructions on front brake pad replacement for this model.
THANKS!!!
THANKS!!!
How is this hitch installed? I don't see why you need to lower the pipes but if you must, the only real way to do it is probably take the pipes off the hangers.
Front pad replacement is pretty much the same as any other car. You need to jack up the car, take off the wheel, disconnect the caliper, replace pads, probably have to recompress your pistons in the caliper, and reverse of what you just did.
Just get lower hangers for your exhaust if you want it to sit lower. Or change the rubber pieces with ones that will allow your exhaust to sit lower. I heard of people using zip ties, but I don't know how safe it is...
NAcivicEK
Apr 11, 2003 05:14 AM
