got a Flat tire on my RR... easiest way to fix?
Yesterday i rode my bike to work and it wasent feeling right.... so today when i got home from school..i FOund out there was a srew in my rear tire...so my tire is half way flat... is it possible to fix this just like a ordinary car tire? or should i buy a new rear tire??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">Ask on a motorcycle forum.
Well, we just happen to have one of those....
there is allot of debate on whether or not to plug/patch on scooters.... the general rule is that if it is towards the middle of the tread like yours it is okay as long as there is enough tread left to justify the fixing of that tire. I however do not plug or patch any of my tires. your gonna need to ride her into a shop or take the rim off and drop the unit at reputable tire shop... don't attempt a fix without prior knowledge. mounting and dismounting is can be a bitch
Modified by MSchu at 4:15 PM 5/18/2006
A good tire store should be able to patch that easy but it requires removal of the tire and applying a patch to the interior wall. You can actually do it yourself with a large patch and rubber cement...if you could get access to the inside. It looks like you have a decent amount of life left to make it worth patching.
i picked up a nail in nearly the exact same spot last summer. I couldn't find anywhere to patch it, and Cycle Gear told me it's better to just replace. I don't feel comfortable riding around on a fixed tire, no matter how reliable it is. I'd rather have total confidence in the two wheels under me. Cycle Gear has good prices on tires, and will mount/balance them for like $14 if you bring them just the wheel.
I've plugged rear tires before...i wouldn't even expletive with it...if it were the front...however i have not had any problems with plugging rear tires, as long as its not on the sidewall.
Hope this helps.
(I rode at least 3k miles on a plug in my old rear shinko before getting a new tire..)
Hope this helps.
the issue, that should be responsibly explained, is that a puncher, and/or a plug displaces cords within the tire, it is not that the tire will not hold air or "blow out", it is that there can be a catastrophic failure/delamitation ... high lite "can be".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HDNBenjamin »</TD></TR><TR><TD CLASS="quote">replace tire..your life is more important than saving a couple of hundreds. </TD></TR></TABLE>
not even that much. you can get another tire for about 130 and get it put on for 20 more .
Go to Cycle Gear and get a new tire .. and with it, get their warranty on it.
I purchased a set of pilot powers from em for my RR .. two days later, my rear wheel looked exactly like yours. Other then paying for mounting and balancing, then replaced it free of charge.
i am having the exact same situation and alot of riders i know say if you got the bread get a new one but plugs should be fine if done correctly... im gonna try and plug mine this weekend *crosses fingers*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Odiedogcx »</TD></TR><TR><TD CLASS="quote">Go to Cycle Gear and get a new tire .. and with it, get their warranty on it.
I purchased a set of pilot powers from em for my RR .. two days later, my rear wheel looked exactly like yours. Other then paying for mounting and balancing, then replaced it free of charge.</TD></TR></TABLE>
cant beat that. i say do that. everyone talks about the little things that could save your life. this COULD be one of them. my $0.02, get a new one.
i had a small tack nail in my tire...guy at the dealership pulled it out and it was fine...no patch. However, looking at that nail and getting a patch..Heck no.
Doing 150 w/ a patch would make me very uneasy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by profroopchan »</TD></TR><TR><TD CLASS="quote">I would plug it and do burnouts for a week, then replace it</TD></TR></TABLE>
I was thinkin of doin that hahaha but Naa... the rear is still pretty new... my friend is gana come by and were going to "plug it" since he did it on his R1 with no problems... thanks for the info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhantomX »</TD></TR><TR><TD CLASS="quote">
I was thinkin of doin that hahaha but Naa... the rear is still pretty new... my friend is gana come by and were going to "plug it" since he did it on his R1 with no problems... thanks for the info </TD></TR></TABLE>
dont get a bike if you cant afford to fix it properly.
plugging the rear tire is HALF-*** and unsafe no matter whos had "goodluck" with it and who hasnt
plug that sh#t, it will be fine ... i have plugged my rear tires 3 times myself and i had no problems... who here has had a problem with a plug???? i dont think many and if they did then they are not doing it correctly but just do what YOU think its proper for the moment and dont belive everything you reed especialy those that ALWAYS seem to have the correct coments they have no life and seem they are always on the forums TOTal post.. 132546 ....DAM!!!!!!! well good luck and keep it easy for the first .... well i dont know 10-50 miles then if it hold then you are good to go .... again good luck peace out....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j600rr »</TD></TR><TR><TD CLASS="quote">plug that sh#t, it will be fine ... i have plugged my rear tires 3 times myself and i had no problems... who here has had a problem with a plug???? i dont think many and if they did then they are not doing it correctly but just do what YOU think its proper for the moment and dont belive everything you reed especialy those that ALWAYS seem to have the correct coments they have no life and seem they are always on the forums TOTal post.. 132546 ....DAM!!!!!!! well good luck and keep it easy for the first .... well i dont know 10-50 miles then if it hold then you are good to go .... again good luck peace out....</TD></TR></TABLE>
you sound very marture and resposiblemy friend, how long have you been riding...
I rode around on my old gsx-r with a plugged rear tire and it held up just fine. My new RC51 came with a plugged tire and I had the rear replaced the very next day. I would NEVER trust a plugged tire on a motorcycle... no matter where the plug is located.
Looking back I still can't imagine why I didn't replace the rear tire on my gsx-r. For $200 bucks I'd much rather know I have a tire that won't blow up on me when I'm riding on the interstate.
