Thanks RSTOR aka Chris S2K Antenna on Integra 4dr
Nice install...although you could have gotten it to tilt a little more than that.
If you want a tilt like the ones on real S2000's, you'll have to cut the white pipe thingy adapter.
But with Chris's kit, you should be able to tilt it as much as 90 degrees without making the antenna stick away/out from the car.
how much is that, my friend bent the sh@t outta mine and now it dosen't get any radio in, I need a replacement...?
looks good..
looks good..
Well that was the best angle I got it to fit. I think with the sedan slopes more than the coupe.. I think Im the first 4dr that done this??
Anyway the kit from Chris was $15 shipped and the S2K antenna is about $15 bucks from the dealer. Toatl of $30 bucks with 20 minutes to install. Now I get good reception again!!
If you're worried about reception, you could buy Chris's s2k kit and they buy a
Insight antenna instead of the s2k antenna. The insight one longer and bolts right on to the s2k kit I heard.
Check out honda's s2k section and they have it listed there.
2K_TEG
Sep 23, 2003 03:33 PM
Cone
Jul 13, 2002 07:42 PM
