need some ideas -- B18C1 won't start
Old May 18, 2006 | 06:55 AM
Driven's Avatar
Default need some ideas -- B18C1 won't start
recently had my engine rebuilt. I put the head on the block, camshafts to the head, etc, etc.
Set the #1 piston at TDC before installing cams. set those at TDC.
timing belt on. then tossed the engine into the car ('90 CRX w/ obd1; obd0 injectors).
Everything worked BEFORE the engine came out...
tried to crank it over and the starter is spinning the engine... except that's the only noise being made... the engine spinning.
So, here's what i've done:
- rechecked timing
- installed another distributor
- checked for fuel pressure (gots it)
- checked to see if #1 spark plug is firing
- tried regrounding a few straps
- used a different main relay
- checked all fuses
the only thing I haven't done is tried a different ecu. it seems like I'm getting spark/fuel/air.... i'm guessing timing is off somehow... but everything matches up. No wiring changes were done to the timing.
firing order is:
3 - 4
1 - 2
Correct? if so, i'm stuck... have no clue what to check next...
Old May 18, 2006 | 10:13 AM
Driven's Avatar
Default Re: need some ideas -- B18C1 won't start (Driven)
the wealth of knowledge on H-T and no one can provide some ideas?
Old May 18, 2006 | 01:43 PM
Slamaccord's Avatar
Compression test?
Any codes?
Old May 18, 2006 | 02:16 PM
PLAN:B's Avatar
Default Re: need some ideas -- B18C1 won't start (Slamaccord)
If you have not done so already, check the ground on the thermostat housing. Also, have you checked to see if the injectors are dumping fuel?
Old May 18, 2006 | 10:26 PM
Driven's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slamaccord &raquo;</TD></TR><TR><TD CLASS="quote">Compression test?</TD></TR></TABLE>
after struggling for awhile, a friend stopped by and gave this same advice. zero compression across the board.
So we adjusted the valves (never did it after installing the cams). once done, the damn thing fired up almost immediately!
Old May 23, 2006 | 05:25 PM
Slamaccord's Avatar
Glad to hear shes running
xchikon
Jul 11, 2014 11:24 PM
Slen17
24
Jun 28, 2012 09:10 PM
:::SIRll_EJ1:::
Feb 6, 2010 12:55 PM
90crxef
Mar 29, 2008 03:15 PM
mrfisher
12
Jul 30, 2005 01:15 PM
