HELLLP!!! wiring pinout for DUAL stereo XDV8125
hey guys, i need some help, if anyone has a pin out for a DUAL stereo, i have a dual XDV8125 and i lost the wiring harness for it, i found one from an alpine that fits, but the wires are in a diffrent spot. any harness from any dual stero will work i really apreciate it if anyone can help
abe
abe
Looking at the harness with the wires exiting towards you and going from left to right starting with the top row....
12v, switched ignition, r/r-, r/r+, r/f-, r/f+, l/r+, l/r-
ground, rca, rca, rca, blank, amp turn on, l/f+, l/f-
Check best buy or circut city for the correct plug though if you can, usually they have them lying around because they use smart harnesses. Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Check best buy...usually they have them lying around because they use smart harnesses</TD></TR></TABLE>
No they don't.
No they don't.
awsome help,, ill check it out and see if it works. a pic would help alot too.. ive been a member for a long time, but everything i need, i always find with the search button. either way thanks alot for the help.
CivicRider011
Audio / Security / Video
Dec 10, 2006 07:07 PM
unclejemima
Sep 13, 2004 01:10 PM
