1992 accord d4 light won't come on.
Old May 17, 2006 | 11:11 PM
Mike17's Avatar
Default 1992 accord d4 light won't come on.
I just replaced the TCM in my sisters 92 accord because the trans was acting up and the d4 light would stay on even when i wasnt in that gear. it also would start in second gear some times when i would first start going. I search on here and learned that it was the tcm going bad so i replaced it.
now the D4 light wont come on. tranny shifts fine and everywhing. the steering wheel used to shake bad when you would put in reverse, not anymore. all other lights come on when the should, just not the d4 light. is this bad or is it maybe just the bulb?
Old May 18, 2006 | 05:04 AM
mycb7.com's Avatar
Is it the D4 light on the instrument panel or the one by the shifter?
Old May 18, 2006 | 05:56 AM
S CARTER's Avatar
Default Re: 1992 accord d4 light won't come on. (Mike17)
I'd start with a bulb.
From honda:
The shifter bulb is P/N 35505-SA5-003 and it's 3.68
and the meter bulb is P/N 37102-SE3-003 and it's 1.30
u might be able to find them aftermarket for a little cheaper, but then u have to pull the bulb out and match it up if they don't have a listing.
Old May 18, 2006 | 06:17 AM
Mike17's Avatar
Default Re: 1992 accord d4 light won't come on. (S CARTER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycb7.com &raquo;</TD></TR><TR><TD CLASS="quote">Is it the D4 light on the instrument panel or the one by the shifter?</TD></TR></TABLE>
the light in the gauge cluster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S CARTER &raquo;</TD></TR><TR><TD CLASS="quote">I'd start with a bulb.
From honda:
thanks. ill try that first. i hope its only that
u might be able to find them aftermarket for a little cheaper, but then u have to pull the bulb out and match it up if they don't have a listing.</TD></TR></TABLE>
thanks. i hope its only that
vdawg559
Jan 31, 2008 09:55 AM
honda genome
Dec 14, 2006 05:41 PM
