Do you really have to Break In the Clutch
Old May 17, 2006 | 10:26 PM
GDM93Si's Avatar
Default Do you really have to Break In the Clutch
Do you really have to Break In the Clutch?
Yes Or No
If yes how many miles
Clutch is a, clutch master with pressure plate 6 pad clutch disc!!!
installed it today!!!
Old May 17, 2006 | 10:35 PM
redpeppers's Avatar
Default Re: Do you really have to Break In the Clutch (GDM93Si)
manufac. says 500 city miles
Old May 17, 2006 | 10:38 PM
GDM93Si's Avatar
Default Re: Do you really have to Break In the Clutch (redpeppers)
thx...
Old May 17, 2006 | 10:39 PM
SOHC4life 96's Avatar
No you don't have to break in the clutch. If you like buying new ones and replacing them a lot then you don't have to break them in at all.
The logical answer is yes. But it sounds like you just can't contain yourself from doing m4d t1gHt 6 puc bUrn0uts! Look at what the instructions say for your clutch, I just installed an exedy organic stock replacement and they say 750 city miles.
Another question, what do you have done to the engine?
Old May 17, 2006 | 11:22 PM
GDM93Si's Avatar
Default Re: Do you really have to Break In the Clutch (SOHC4life 96)
um Stock GSR with 9psi 306 whp..
Old May 17, 2006 | 11:24 PM
Really? 309? What turbo are you running?
Old May 17, 2006 | 11:34 PM
GDM93Si's Avatar
t3/t4
kevinm1981
Transmission & Drivetrain
Mar 31, 2009 08:34 AM
99fbpem1
17
Aug 13, 2007 10:08 PM
VisPreludeVtec
Sep 25, 2004 10:53 AM
DC-4-Drew
May 13, 2004 04:19 AM
alfaaay
Apr 4, 2003 08:47 PM
