Having an issue... Interemittent "power" cut at 8k sometimes 9k sometimes 7k Rpms...
Old May 17, 2006 | 10:26 PM
Circuit Star-29's Avatar
Default Having an issue... Interemittent "power" cut at 8k sometimes 9k sometimes 7k Rpms...
Very confused but thought I'd post to see if anyone has had this happen to them.
New motor about 1.5 weeks old. Just began doing this when we removed the MSD a few days ago.
At 100% throttle the motor has a power cut-out which feels like a fuel cut. This happens only intermittently and never at the same Rpm... Sometimes at 7500 rpm, sometimes at 9000 rpm...Very lost. Any suggestions within reason would be apprecieated.
Old May 18, 2006 | 09:58 AM
Default Re: Having an issue... Interemittent "power" cut at 8k sometimes 9k sometimes 7k Rpms... (Circuit St
anyone?
Old May 18, 2006 | 10:41 AM
AllMotorMark's Avatar
possible ignitor problem?? try another distributor just to see what will happen ,, see if you could borrow one
Old May 18, 2006 | 04:06 PM
Will be giving that a shot tonight...Any other ideas? All grounds checked....
Old May 18, 2006 | 05:16 PM
i would be its that , but what about ecu? is it chipped i have seen funnier things
Old May 18, 2006 | 07:58 PM
ECU is chipped. Its not the ECU...I dun think. Just incase, Ill swap ecus to see for sure.
Old May 18, 2006 | 08:15 PM
B18C1_POWER's Avatar
I'm having the same problem, but my car makes it constantly like from 8600-8700k 15whp when that **** happens, I'm going to check the distributor, let me know if you solve your problem
Old May 18, 2006 | 09:02 PM
Yea, its a constant occurance now...And yes, It feels like quite a bit of power escapes.
Old May 18, 2006 | 09:20 PM
to be exactlywhen my car makes that loose 15whp and 13lbs of tq, in the road it feels like if the engine has the rev limit set at this rpm and after that moment it continues up
Old May 19, 2006 | 10:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1_POWER &raquo;</TD></TR><TR><TD CLASS="quote">to be exactlywhen my car makes that loose 15whp and 13lbs of tq, in the road it feels like if the engine has the rev limit set at this rpm and after that moment it continues up</TD></TR></TABLE>
Does this happen during turns? Do you still here vtec?
mikej94civex
Jan 9, 2010 02:13 PM
CRXObsession
Jun 1, 2005 08:39 PM
the-pepsi-man
Jan 25, 2005 08:13 PM
ITR0170
Jan 15, 2003 09:05 PM
