need help h22a swap!!?
boost the F23 you'll be alot happier and it'll cost almost the same....just my 2 cents oh and I have a H22 accord...my friends boosted F22 walks on me...the power of boost! gl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bizzaro_29 »</TD></TR><TR><TD CLASS="quote">i need any info. on how to swap a jdm h22a into my accord i have a f23(non-vtec)
any help plz were to look for info??
Check out the search button and look for h22a under the Accord section. What kind of info are you looking for? Any specific questions? Is your car a 5 speed or an auto? Are you looking into swapping in a 5 speed or an auto H22? What year is your car?
</TD></TR></TABLE>Check out the search button and look for h22a under the Accord section. What kind of info are you looking for? Any specific questions? Is your car a 5 speed or an auto? Are you looking into swapping in a 5 speed or an auto H22? What year is your car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HandoEX »</TD></TR><TR><TD CLASS="quote">Check out the search button and look for h22a under the Accord section. What kind of info are you looking for? Any specific questions? Is your car a 5 speed or an auto? Are you looking into swapping in a 5 speed or an auto H22? What year is your car?</TD></TR></TABLE>
yeah, I second this thought.
search or ask some specific questions. good luck w/ the swap, h22 for the win!
well i got a 94 accord 5-speed. i alread got the h22a(jdm) and its also a 5speed i need to know what to swap over to use and not to use. you know step-by-step im on a budget and i want to do it my self and not to pay for it.if anybody could help me find a wed site or something to help a honda community owner out.
Might I suggest that before you even start to look up how to swap the actual engine you go into the Prelude forum and do some things.
You may want to do some of the following: change all belts (including timing), adjust valves, change water pump, h22a auto to h23 manual tensioner swap, change oil and filter, remove intake manifold and check for any carbon buildup.
These are just things that are much easier to do when the engine is outside of the car and could really save you some time. Then once you get all that done swap the engine in and you should be happy when it runs correctly and you don't have to try to do all this with it in the car.
Auto96accord
Aug 13, 2006 04:40 PM
