CRX Headlights Interchangability?
Old May 17, 2006 | 07:58 PM
Ralph Wiggum's Avatar
Default CRX Headlights Interchangability?
I recently got into a fender bender and the drivers side headlight got smashed. CRX's are are to find where I'm from and are usually picked clean within a week in wrecking yards so I'm thinking if EF Hatchback headlights would work in a CRX?
Thanks
Old May 18, 2006 | 04:12 AM
rexerin's Avatar
yes. all headlights from ED civics are interchangable. as far as i know it's one of the only parts that is common among all 3 civic models (CRX, HB, sedan).
Old May 18, 2006 | 07:09 AM
JJ's civic's Avatar
Default Re: (EF ryan)
someone told me that they change there fenders and all they had to do was nugde the coners in and they stay but i won't recomend that
Old May 18, 2006 | 08:47 AM
bearfoot990's Avatar
Default Re: (joeny12985)
NO. the corners one the CRX are different than the hatch the angles are different. i found that out the hard way. but the headlights i know for sure are the same.
Old May 18, 2006 | 08:53 AM
Exempt's Avatar
Headlights themselves are the same... But the brackets are different depending on the year(88-89s and 90-91s)... If you have a 90-91 you will have to swap the brackets off yours if u get a set of 88-89 headlights and vice versa... Corners will not work either without fenders...
Modified by Exempt at 11:32 AM 5/18/2006
Old May 18, 2006 | 09:04 AM
pinecone's Avatar
Default Re: (Exempt)
Just had the same experience. 91 civic corners are a different angle and smaller than 91 crx corners. But the headlights are the same.
Old May 18, 2006 | 06:32 PM
Thanks for the help
93delboosted
Mar 22, 2012 06:08 AM
Moo-Moo
13
Jul 5, 2010 12:50 AM
Lethalb18c1
Feb 12, 2007 01:03 AM
youtouchmytralala
43
Feb 26, 2006 02:04 AM
Jester88Si
Feb 17, 2004 06:25 AM
