does anyone have bight corner light
Old May 17, 2006 | 07:12 PM
SFlCrx's Avatar
Default does anyone have bight corner light
did honda make the the corner light very dim on all crxs or is it just my friend and mine. is there an aftermarket bulbs that put out more watts? lmk
finaly done with the engine work now just need some jdm flava and i'm done with her... i know thats what everyone says
Old May 17, 2006 | 07:17 PM
johnclaunch's Avatar
Default Re: does anyone have bight corner light (SFlCrx)
The corner light lens is sort of tinted. Yes, it is dimmer than the amber side light. From my experience there are no brighter bulbs you can use that won't damage the wiring. The best thing is to get all amber corners.
Old May 17, 2006 | 07:19 PM
Crx Jimmy's Avatar
the corner lights are dim, 5 watts, make sure your replace it with a 168 bulb not a 194 bulb which have the same base, but the 194 bulb is only 3 watts
Old May 17, 2006 | 07:22 PM
Rex-Si's Avatar
Default Re: does anyone have bight corner light (Crx Jimmy)
I went with crystal clear corners with amber bulbs and its bright as hell.
same set up on the bumper , the signal lenses have a prism effect and are also using bright amber bulbs.
xprometheusx
Aug 22, 2014 10:39 AM
EG-SIXV-TEC
Apr 16, 2010 10:38 PM
EK_kidd
Lighting
Oct 8, 2008 08:45 AM
143MYVTECEF
11
May 29, 2007 08:40 PM
nerdish
Mar 6, 2004 08:44 PM
