Help: Speedo not working
Old May 17, 2006 | 06:03 PM
endlesswinterco's Avatar
Default Help: Speedo not working
yes, ive searched didnt find much that helps. the speedo was jumpin and then stoped working, eg. eveyrthing else works fine, just the speedo doens't. connection on at the plugs seems fine. is it the speedo cable? thanks.
~ben
Old May 17, 2006 | 06:44 PM
FalkenSiR's Avatar
Default Re: Help: Speedo not working (OEMben)
You don't have a speedo cable. Welcome to 1992. I would trace the VSS wiring and look for an open in the wires.
Old May 17, 2006 | 09:44 PM
92_VX_EG's Avatar
Had the same problem. Either there is moistur on the VSS where it doesn't work right or you need to replace the VSS. They are different for autos and mannys.
Old May 17, 2006 | 09:50 PM
Eran's Avatar
HT White Ops
my friend's speed sensor was acting up, and he took it all apart and hosed it with carb cleaner. turns out that it was just gunked up and the gear wasn't turning.
Old May 17, 2006 | 09:57 PM
axtran's Avatar
could be your wire too, mine's corroded to total crap and i need a new one (which is coming in the mail )
superslowcrx91
May 8, 2013 08:10 PM
Turbo Dan
10
May 15, 2008 11:25 PM
TMC_EF
Jul 16, 2007 10:37 PM
crexer
Nov 4, 2005 03:47 PM
Snail Tuning
Dec 29, 2002 10:44 AM
