Found the culprit!
Old May 17, 2006 | 05:13 PM
Utilitarian's Avatar
Default Found the culprit!
This would explain alot of things! I guess it is 10 years old.
The good news is that it wasn't nearly as much of a son-of-a-bitch as I thought it would be to replace. The only really difficult thing was getting the 19mm bolts to break loose on the brace. PB blaster + pushing the breaker bar will the foot gets the job done.
The bottom line for people searching for info in the future- you don't need to remove the intake manifold.
Old May 17, 2006 | 05:44 PM
RTW DC2R's Avatar
you using inserts for that?
Old May 17, 2006 | 05:45 PM
KayOs's Avatar
Default Re: Found the culprit! (Utilitarian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Utilitarian &raquo;</TD></TR><TR><TD CLASS="quote"> you don't need to remove the intake manifold. </TD></TR></TABLE>
That will always be good news
Did you go with replacement mount or insert?
Old May 17, 2006 | 06:14 PM
fcbayern's Avatar
Default Re: Found the culprit! (KayOs)
What problems did it cause?
Old May 17, 2006 | 06:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs &raquo;</TD></TR><TR><TD CLASS="quote">
Did you go with replacement mount or insert?</TD></TR></TABLE>
Just a stock mount. I did the two front ones before doing this one, hoping it would save me the work of the this (the rear) one.
The engine was jerking really bad with throttle/clutch modulation.
Old May 18, 2006 | 06:30 AM
Aquafina's Avatar
making strange noise while moving in gear by any chance?
Old May 18, 2006 | 06:32 AM
ebelp's Avatar
Default Re: Found the culprit! (Aquafina)
That would've been a perfect time to put in some inserts....that wouldn't help your jerkiness/vibrations though.
Old May 18, 2006 | 06:39 AM
BlueR's Avatar
Default Re: Found the culprit! (ebelp)
pretty typical, this was mine when i removed it:
Old May 18, 2006 | 07:13 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: Found the culprit! (BlueR)
Originally Posted by Utilitarian
The bottom line for people searching for info in the future- [B
you don't need to remove the intake manifold.[/B]
Told you!! jk
Glad you got it done without going thru that hassle
Old May 18, 2006 | 07:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">That would've been a perfect time to put in some inserts....that wouldn't help your jerkiness/vibrations though.</TD></TR></TABLE>
Yeah I'm not interested in reducing wheel hop on the launch. I don't think ES'es are legal in DS auto-x anyhow.
Old May 18, 2006 | 07:44 AM
cmdr430's Avatar
nice to see you got it fixed Matt....
I may be giving you a call in the next couple of days.....
Old May 18, 2006 | 08:27 AM
realis9's Avatar
Default Re: Found the culprit! (cmdr430)
what is that mount call? in case i need to order one from acura.
Old May 18, 2006 | 08:33 AM
Default Re: Found the culprit! (realis9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 &raquo;</TD></TR><TR><TD CLASS="quote">what is that mount call? in case i need to order one from acura. </TD></TR></TABLE>
The Bible:
http://www.barancoacuraparts.c...l=All
Bookmark it!
Old May 18, 2006 | 08:59 AM
Rcp's Avatar
Rcp
what are some symptoms of this culprit?
Old May 18, 2006 | 09:57 AM
Arsenal's Avatar
Default Re: (Rcp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcbayern &raquo;</TD></TR><TR><TD CLASS="quote">What problems did it cause?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Utilitarian &raquo;</TD></TR><TR><TD CLASS="quote">
The engine was jerking really bad with throttle/clutch modulation.</TD></TR></TABLE>
Old May 18, 2006 | 09:18 PM
Madspeed's Avatar
glad to see its fixed now.
Old May 19, 2006 | 07:20 PM
94rs-turbo's Avatar
i hate replacing motor mounts ecspecially the tranny mount that one is the worst
Old May 19, 2006 | 08:42 PM
Mythias's Avatar
Glad to hear you found and corrected the culprit. Now that I have 97 #347 back, I will be ripping the motor back out for some upgrades and new motor mounts are on the agenda.
Old May 20, 2006 | 07:01 AM
Mires's Avatar
Default Re: Found the culprit! (Mythias)
Did you experience any steering wheel vibration at highway cruising speeds or at anytime while pressing on the gas more than 1/4 of the way down? If im going on the highway between about 70 and 90 I get a slight steering wheel vibration that isn't bad but annoying. Its weird cause if Im going much faster than that (which I rarely do) it seems to go away. It also happens while getting on the gas a little bit. I have tried everything to fix it and nothing has worked. This might be my answer. I know my mounts have well over 100,000 miles on them. Anyway, glad you found your answer.
Old May 20, 2006 | 08:55 AM
cryptikman's Avatar
Default Re: Found the culprit! (Mires)
Damn. Looks like I better check mine, just in case.
Justin Olson
Welding / Fabrication
25
Nov 1, 2007 05:44 AM
Dat1BVtecN
91
Apr 27, 2007 10:26 AM
Coach McGuirk
Feb 26, 2007 07:10 PM
numbnuts22715
Jan 16, 2007 03:23 AM
Garrett
Jul 20, 2003 11:44 AM
