supposedly I am not allow to run pump 91 gas on 11.5:1+ compresson any explanation why?
Old May 17, 2006 | 05:03 PM
b16nonoy's Avatar
Default supposedly I am not allow to run pump 91 gas on 11.5:1+ compresson any explanation why?
I was just curious to why its not a good pimture? is it cause its a higher compression and needs a more flamable gasoline to combust in the cylinder chambers??
my complete setup should probably be 12:1 with my head being milled, block decked resurfaced twice and my head gasket..
Old May 17, 2006 | 05:05 PM
Spec911's Avatar
Default Re: supposedly I am not allow to run pump 91 gas on 11.5:1+ compresson any explanation why? (b16nono
Um no problems. All you need is an excellent cam to balance the compression out and a great tune. I mean damn near perfect. 91 octane is low.
Old May 17, 2006 | 05:13 PM
b16nonoy's Avatar
I am wanting to buy the Toda Spec B cams..
I have JE 11.5:1 83mm pistons...eagle h beam rods. my whole rotating assembly was balanced to 10,000rpm..and my head is stage 2/3 port and polished with KMS developement(might change my springs to todas as well)98 spec type r header with spoon sports exhaust will be attached to it....
b16 tranny with type r lsd and final drive 4.785
I was told I couldnt use pump gas on my setup...
Old May 17, 2006 | 05:58 PM
MR_Ek4's Avatar
you should be fine on pump gas. there is a million threads about this search and maybe it will be some more help. Is your block sleeved?
Old May 17, 2006 | 06:00 PM
b16nonoy's Avatar
yes..here is wjhat my block looks like...check this link
https://honda-tech.com/zerothread/1628670
Old May 17, 2006 | 06:14 PM
MR_Ek4's Avatar
ahh nice that explains the 83mm pistons. Good luck
thegeezerkid
Apr 2, 2009 06:24 PM
Manny86
May 10, 2008 11:21 PM
11KRedline
18
Jul 9, 2007 11:38 PM
THC07
May 29, 2007 07:26 PM
UltRaH22
Feb 12, 2003 11:13 PM
