B16 A2/ Help Wanted
Old May 17, 2006 | 04:41 PM
Barcode's Avatar
Default B16 A2/ Help Wanted
I have a 1988 civic CRX SI. I'm putting a 1999 civic B16 A2 motor in the crx. I need to make sure, but I need the OBDO to OBD1 cpu harness, correct?
Also, do you guys have any tips for when I swap out the motors?
Old May 17, 2006 | 04:49 PM
thevtecnician's Avatar
Default Re: B16 A2/ Help Wanted (Barcode)
Your running it as obd1 right? Then you do need a jumper harness for your ecu. Here's a tip: when your pounding on your axles trying to get them out of the hub, LEAVE THE NUT ON! Don't mushroom the threads
Old May 17, 2006 | 04:59 PM
Barcode's Avatar
Default Re: B16 A2/ Help Wanted (thevtecnician)
Yeah, I think that is the best way to go.
ERKK
23
Mar 9, 2009 04:25 PM
newtype_civic
Nov 6, 2007 06:54 PM
