water leak on car
Old May 17, 2006 | 04:21 PM
vietkangta's Avatar
Default water leak on car
i notice theres somethign that looks like water dripping from the right side of my car in the front. Do i ahve a problem? I just recently replaced the hose and stuff for my coolant so i dont know what the leak is.
Old May 17, 2006 | 04:28 PM
BLKFLSH's Avatar
Default Re: water leak on car (vietkangta)
Could it be the air conditioner drain tube? If you have a moonroof, it will drain out of a hose down there too. Is it under the engine?
Old May 17, 2006 | 04:40 PM
vietkangta's Avatar
Default Re: water leak on car (BLKFLSH)
its not really under the engine its more to like the back of the front on the right side near some tube i can see when i look on the bottom.
i have a sunroof. my accord is a 94 ex model.
Old May 17, 2006 | 06:13 PM
YeuEmMaiMai's Avatar
if it's green then you got problems. If it is just water then you have nothing to worry about since it is just condensate from the evaporator and it is draining out via the drain tube under the car on the passenger side (right side)
Old May 17, 2006 | 07:20 PM
BLKFLSH's Avatar
The moonroof is not designed to be a watertight seal at the roof. It has a drainage system (gutter, and drain hose) to catch the water that comes through between the glass and roof.
Old May 17, 2006 | 08:28 PM
HONCORD's Avatar
If its coolant can it be the reservour bottle too full and it just leaks out some when its hot?
dth0ng69
18
Jul 19, 2009 09:12 AM
joelmatt89
21
Apr 15, 2009 06:16 PM
milanoredgsr
Feb 24, 2008 11:14 AM
Jun 10, 2004 08:56 PM
lonefuzzy79
Sep 30, 2002 02:54 PM
