2nd gear grinds but other gear is fine
Old May 17, 2006 | 03:11 PM
Pnoyej6's Avatar
* B A N N E D *
Default 2nd gear grinds but other gear is fine
im putting syncromesh. how many qts i need for crx si?
Old May 17, 2006 | 03:18 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: 2nd gear grinds but other gear is fine (pnoytegn707)
how do i drain tranny fluid in crx? and how do i fill? where is it located in tranny drain bolt?
Old May 17, 2006 | 03:24 PM
Pnoyej6's Avatar
* B A N N E D *
bump
Old May 17, 2006 | 03:30 PM
davens's Avatar
bump...since its overdue
Old May 17, 2006 | 04:50 PM
shortyz21's Avatar
Default Re: (davens)
the drain bolt on the tranny is a square 3/8 bolt at the bottom of the tranny. u stick the end of your ratchet in there.
the fill bolt is the 17mm nut just up from the fill plug..
i find it easier to fill through the reverse gear sensor plug or the big *** bolt on the top of the tranny..
good luck. i will tell you the 17mm bolt will be tight as expletive, i hope u got a decent wrench cause u will have to lay under the car and kick the wrench to bust the bolt loose.
^ sometimes
Old May 17, 2006 | 05:37 PM
gospeedgo1's Avatar
Default Re: (shortyz21)
i think its 1-1/2 bottles of the syncromesh. i did that several months ago. it helped a lot but it still does it every now and then. i think the shifter bushing needs to be replaced. 18 year old rubber has to be worn out by now.
Old May 17, 2006 | 07:36 PM
Contender25
Guest
Posts: n/a
Best advice overall, get new shifter bushings, and some syncromesh. The both of those together should cut down on tranny wear for a while at least, and shifting should be noticable better until you trash it and do a swap.
Ef4doorwagon
Aug 7, 2014 10:36 PM
rockcity
14
Aug 21, 2008 10:52 PM
trevorjohn88ef
12
Jul 2, 2008 11:35 AM
lke2drvgsr
Apr 6, 2004 02:49 PM
asubennett
Aug 21, 2003 05:14 PM
